C6 quest's
Old Dec 5, 2002 | 10:54 PM
elliott's Avatar
elliott
C6 quest's
I am looking at having a C6 rebuilt just for 5th wheel,HD towing, behind a 460. Sugestions for Torque Converter, lower gear set, etc.
(I already have trans cooler, temp gauge, deep pan). Thanks for any input. Elliott
Old Dec 5, 2002 | 11:15 PM
Ford_Six's Avatar
Ford_Six
C6 quest's
For a torque converter, a stock stall would be fine, but I would definetely go with the low gear set. I would use the Borg-Warner clutch/steel/band set from KDS Performance, but which fluid you run is up to you. Pre-76 is type F, post 76 is Mercon/Dexron. As for a shift kit, I would use a mild performance kit, or a specific tow/haul kit.
Jared
Old Dec 6, 2002 | 10:22 AM
mrshorty's Avatar
mrshorty
C6 quest's
Matt Elliott
Sep 25, 2016 06:31 PM
elliott78
Jun 27, 2014 05:50 PM
elliott
Dec 21, 2002 12:24 AM
elliott
Dec 11, 2002 10:42 PM
elliott
Dec 7, 2002 12:40 PM
