Transfer case
Old Jan 2, 2003 | 09:22 PM
blownbronco's Avatar
blownbronco
Transfer case
Hey guys, i just changed my tranny fluid 3 days ago. I want to change my transfer case fluid now. Is it ok to do this. thanks alot!
Old Jan 2, 2003 | 10:09 PM
MustangGT221's Avatar
MustangGT221
Transfer case
Sure thing.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Jan 2, 2003 | 10:17 PM
mikemc's Avatar
mikemc
Transfer case
On my '97 it was recommended every 30K miles. You have to siphon out old fluid, make sure to use correct fluid as posted in owners manual, probably Mercon ATF.
Old Jan 3, 2003 | 07:57 AM
steve83's Avatar
steve83
Transfer case
All the Bronco t-case have drain plugs - probably the pickups, too.
Old Jan 3, 2003 | 12:09 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Transfer case
My 90' has the drain plugs. One to drain, one to fill. They are both on the rearward side of the case. And Blownbronco, I would change it. I think it takes 4 quarts. Mercon ATF.
Old Jan 3, 2003 | 02:42 PM
blownbronco
Transfer case
Ok, guys I'm going to change it tomarrow! My maual says the transfer case only takes two quarts of Mercron ATF!
Old Jan 3, 2003 | 11:25 PM
steve83's Avatar
steve83
Transfer case
Right - 2qt.
Old Jan 3, 2003 | 11:29 PM
steve83's Avatar
steve83
Transfer case
willpjones
Aug 19, 2016 02:41 PM
fishbones182
Dec 30, 2015 07:24 AM
timbersteel
Aug 26, 2013 12:56 PM
mklemin
May 7, 2008 02:31 PM
mycam8u2
Dec 13, 2007 08:24 AM
