oil
Old Apr 6, 2009 | 06:32 PM
tjbeggs's Avatar
tjbeggs
The oil flows from the pan through the pickup tube to the pump, out to the oil cooler thru the filter then to the rest of the engine. The only exception is right at start there is a short circuit to feed the HPOP reservoir without going thru the filter.
I do not know how long it takes for the filter to fill but its pretty fast. You would have oil pressure faster prefilling the filter no doubt. But imo there is neglible gains prefilling the filter.
I don't want to steer anyone away from prefilling though. I think it is a good thing I just don't do it.
Just some food for thought though. The Wix 1734 filter is rated at 30 GPM. That per MINUTE. Our trucks flow a lot of oil through the system. Perhaps I will time oil pressure times one of these days. Not by the stock gauge though as its not in the correct spot ot get a good picture of what is going on at the filter.
1dieselman's Avatar
1dieselman
Pump fills filter then from filter out to bearings. With a hot engine it doesn't take long for the bearings to wipe the oil off the journals as the oil system is pressurizing. A lot of engines that I work on sometimes the oil filters are remote mounted plus can have two or more filters so it can take a bit for the system to pressurize so for me it has become habit to pre fill the filters
Old Apr 6, 2009 | 06:36 PM
444dieselrod's Avatar
444dieselrod
Originally Posted by tjbeggs
I don't like to spill oil when trying to spin the filter. Also with the angle of the filter its a lot easy to get the threads started with it empty. On the hundreds (may thousands?) of vehicle I have changed the oil I don't fill the filter.
In the grand scheme of things I don't think the one start every 3-5K will matter compared to the hundreds of cold starts the vehicle sees between oil changes.
hey TJ, just dont fill it full then it wont spill while wobbiling the thing into place.
who ever thought an oil filter tilted 4 degrees was a good idea is an idiot.
Diesel Rod, who prefills
Old Apr 6, 2009 | 06:40 PM
tjbeggs's Avatar
tjbeggs
Yeah I know I could fill it part way. I don't know just never do. I would like to find the engineer that put it at an angle! WHY WHY WHY!! I feel a mod coming on......
Old Apr 6, 2009 | 06:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Well thanks for the explanation and I agree that prefilling is good thing, maybe Im going to do it next time. but I would like to know the results of the oil pressure times.
Old Apr 6, 2009 | 08:20 PM
arkredneck's Avatar
arkredneck
i never pre fill the filter on any thing i have ever worked on don't see why it would matter unless it's a remote mount unit. but you could always but the filter on empty pull a fuse and crank until you see oil pressure and then no mess and still no dry start up
jonrjen
6.7L Power Stroke Diesel
35
Dec 27, 2014 09:00 AM
jimmycat
6.4L Power Stroke Diesel
15
Jun 22, 2010 06:33 PM
GoCamping
Aug 26, 2007 10:12 PM
RetiredCDF'er
Jul 24, 2007 08:18 AM
omni
General Automotive Discussion
32
Oct 17, 2004 09:31 PM
