how many fuel pumps
Old Mar 30, 2009 | 06:50 PM
colorsink's Avatar
colorsink
how many fuel pumps
90 f150 4.9 one gas tank in back does this just have the intank pump or is there another pump on the frame rail
Old Mar 30, 2009 | 06:53 PM
subford's Avatar
subford
Just the pump in the tank.
Old Mar 30, 2009 | 07:26 PM
1966Tbird's Avatar
1966Tbird
i have an 89 5.0 aod with a pump in the tank and one on the frame for what it's worth
Old Mar 30, 2009 | 08:02 PM
subford's Avatar
subford
If you have an 89 you sure do.
Old Mar 30, 2009 | 08:37 PM
1966Tbird's Avatar
1966Tbird
didn't know that 90 was when they made the switch to just single intank pumps
Old Mar 30, 2009 | 08:40 PM
superduty79's Avatar
superduty79
myself once a pump goes i go aftermaket.....
Old Mar 30, 2009 | 09:17 PM
1966Tbird's Avatar
1966Tbird
i doubt you can make enough power with a 300 to use more fuel that the stock pumps can provide, with a 5.8 5.0 or 460 then yeah it's not too hard to do
Old Mar 30, 2009 | 09:26 PM
colorsink's Avatar
colorsink
thanx for all the help
Old Mar 31, 2009 | 08:14 AM
subford's Avatar
subford
didn't know that 90 was when they made the switch to just single in-tank pumps
In 1990 Ford F-series gas trucks went to just the in-tank pumps, the E-series did it in 1991.
The in-tank 1990+ pumps put out about 100 PSI against a blocked head.
They are rated at 125 LPH (33 GPH) @ 310 KPA (45 PSI) so the stock pumps can put out more than enough fuel for the 460.
A 460, 351 & 302 have a top fuel pressure of 45 PSI (310 KPA) and a 300 engine 60 PSI (415 KPA) so there is no problem. If you want more than you would have to go with an adjustable fuel pressure regulator.
The Injectors Flow #/HR are for the 300 = 14#/HR, 302 & 351 = 19#HR and the 460 at 24#HR.
So the injectors @42 PSI for the 14#HR = 2.45 GPH, 19#HR = 3.3 GPH & 24#HR = 4.2 GPH.
So a 460 at WOT = 33.6 GPH @ 42 PSI and that would be enough fuel with a 33 GPH @ 45 PSI as the pump would put out more GPH at 42 PSI.
Any engine under the 460 would have more than enough fuel.
Sorry I do not have information on the 1989 an older fuel pumps ratings but would think Ford would have put large enough pumps on them also.
beartracks
22
Sep 2, 2004 10:35 AM
jearl
Jan 1, 2003 03:49 PM
JBronco
1978 - 1996 Big Bronco
Dec 2, 2002 05:34 PM
restorit
Jul 15, 2002 09:25 AM
proeliator
Jan 1, 2001 03:29 PM
