Sponsored by: Auxito
Power window making noises
Old Mar 28, 2009 | 09:08 AM
RobbyMartin's Avatar
RobbyMartin
My driver and passenger side power windows make noises (popping and grinding type noise) when rolling down and up. Its been doing this for years and they both work properly but the noise is really getting at me. What makes this even more odd is that it doesn't do it when it's cold outside. I took the door panels off to see if there was any interferences or broken pieces and there wasn't. Any of you guys out there have this problem?
Old Mar 29, 2009 | 01:06 PM
dadlovesfords's Avatar
dadlovesfords
Try lubing the mechanisms with graphite spray , WD40 , or the such. Make sure the cable drive isn't just loose laying in the door. Lube the tracks too.
Old Mar 29, 2009 | 08:57 PM
steve(ill)'s Avatar
steve(ill)
i used spray lithium white grease to lube the track and glass guides. take the panel off, put window 1/2 way open, and spray all the slides, wheels, and guides.
Old Mar 29, 2009 | 08:58 PM
steve(ill)'s Avatar
steve(ill)
a good silicon spray works good on the window track.
droppedf100
Feb 22, 2010 06:48 PM
RobbyMartin
1997 - 2003 F150
Dec 25, 2009 10:15 AM
mfwhite22
Feb 9, 2009 10:00 AM
jklumb
New Member Introductions
Mar 31, 2008 12:25 AM
WXboy
1983 - 2012 Ranger & B-Series
May 1, 2003 08:23 PM
