Power steering noise
Old Oct 4, 2007 | 07:03 PM
mfwhite22's Avatar
mfwhite22
Question Power steering noise
When I turn the wheel either direction on my 04 EB 6.8 X the power steering makes a noise that sounds like an old door creaking open and close. I don't recall this being like this before, and can even hear it drivng if the windows are down. the noise stops as soon as I stop turning the steering wheel.
Any thoughts??
Thanks...
Old Oct 4, 2007 | 09:00 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Just an obvious thought...have you checked the power steering fluid?
joe.
Old Oct 5, 2007 | 07:00 AM
mfwhite22's Avatar
mfwhite22
Duhh!! I should have thought of that, will do this morning.....
Thanks
Old Oct 17, 2007 | 09:36 PM
mfwhite22's Avatar
mfwhite22
I checked the power steering fluid and topped off, still getting noise. It is coming only from the left front and seems like it is one of the bushings just on the inside of the wheel. I tried lubing it and got a little decrease in the noise...what do you think, time for the dealer....
Old Oct 18, 2007 | 06:32 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
mfwhite22,
I'm out of suggestions...sorry...one and done i guess!...
Hopefully someone will chime in with an idea for you...
Is the truck still under some extended warranty or something?...if not...you may want to find a good local guy you trust as stealerships get their name for a reason!
Good luck and sorry I couldn't help more.
joe.
Old Oct 18, 2007 | 07:09 AM
CanadianSmokie's Avatar
CanadianSmokie
Check your ball joints... my Mercedes was making the same creaking noise when the wheel was turned and it turned out to be a dry ball joint.
Hope this helps...
Old Feb 8, 2009 | 03:56 PM
mstiles19's Avatar
mstiles19
hey just wondering if you ever figured out the problem? mine seems to be doing the same thing. thanks
Old Feb 8, 2009 | 05:39 PM
cbradford's Avatar
cbradford
Ball joints would be my guess as that's why I replaced mine. The factory Ball joints have no grease fitting, if you have replacement Ball Joints you may have grease fittings and could try to grease them.
Old Feb 9, 2009 | 08:43 AM
vettdvr's Avatar
vettdvr
Hope this helps...
Check your ball joints... my Mercedes E500 was making the same creaking noise when the wheel was turned and it turned out to be a dry ball joint. This was replaced under my warranty. But I suspect you have a bad joint and it could fail. You might have someone turn the wheel and listen for the sound.
Old Feb 9, 2009 | 10:00 AM
mstiles19's Avatar
mstiles19
just wondering if the op can confirm the ball joints.....cause i am 99% sure it is not the problem
GormGorm
Jul 18, 2012 02:42 AM
hosoria
Sep 17, 2010 03:32 PM
one_wicked_element
Modular V10 (6.8l)
Dec 3, 2007 12:22 AM
orthogod1
Jul 12, 2007 05:57 PM
bremen242
1997 - 2003 F150
Nov 6, 2005 09:32 AM
