Trans decoder?
Old Mar 26, 2009 | 03:30 PM
J1MMY's Avatar
J1MMY
Trans decoder?
Is there a link to a transmission specific decoder on the net? I'd like to know whats sat on the back of my 302.
PGD AW15 G29
E1TP EB 010612
Old Mar 26, 2009 | 03:37 PM
Lazy K's Avatar
Lazy K
Have you tried the VIN decoder in "Articles/Specs" in the bar along the top of the page?
Old Mar 26, 2009 | 03:39 PM
85e150's Avatar
85e150
You might get a decode here, or looky at yours, then looky at these:
Automatic, from the Articles/Specs section up above where you are looking right now:
https://www.ford-trucks.com/article/...ers_Guide.html
Manuals:
Domestic Truck Tranny Guide
Old Mar 26, 2009 | 03:46 PM
J1MMY's Avatar
J1MMY
Manuals:
Have that saved to faves already.
Thing is, it's not the original engine/trans combo to the truck so can't match it up.
Old Mar 26, 2009 | 09:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no transmission information in the VIN.
Old Mar 27, 2009 | 12:31 AM
85e150's Avatar
85e150
So when you look at the trans, you can't match it to the descriptions or the pics?
What is it anyway, I think you might have posted once, but I forget. Auto, stick, 3 speed, 4, OD, what?
Old Mar 27, 2009 | 02:04 AM
J1MMY's Avatar
J1MMY
3 spd auto, integral bellhousing, oil cooler pipes exiting on the pass. side to the rad?
Old Mar 27, 2009 | 03:06 PM
85e150's Avatar
85e150
All aluminum integral bell 3 speed auto trans from Ford would be the C6.
C4 and C5 are aluminum, but separate bell.
Look at the pan and see how many bolts, shape etc, and you can match from there via the trans spotters guide.
Old Mar 27, 2009 | 03:11 PM
J1MMY's Avatar
J1MMY
Damn lol I was hoping on hope it would turn out to be a C4 - C6's suck up a lot of power on its way from the crank to the wheels, from what I've read.
thanks for the info
Old Apr 6, 2009 | 01:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Right here on FTE: I can decode all of them manual & automatic.
I'd like to know whats sat on the back of my 302. / PGD AW15 G29 / E1TP EB 010612
PGD-AW-15 // E1TP-EB = C6 Transmission / Original application: 1981 F250/350 300 I-6.
Where's the post that has the Ford parts tag info?
EDIT: Nevermind, I found it. There nothing fishy about that label at all. It's not a Ford parts label, either.
It's the frame manufacturer's ID label, as Ford did not make their own frames. Prolly American Frame & Axle, as Ford used this company for decades to make all their frames.
These ID tags were usually installed on the passenger side outer frame rail, about a foot or so to the rear of the front frame horn on every car/truck beginning in the 1930's.
Actual Ford part numbers do not appear on any parts after 1956. Only ID numbers can be found on parts.
If you do find a stenciled part number or parts tag/label on a part, it wasn't installed at the factory.
The specific labeled part was purchased from a dealer and installed later. Usually this is seen on body parts replaced due to damage.
Old Apr 6, 2009 | 01:40 PM
J1MMY's Avatar
J1MMY
N.D, you are a legend. Thank you for the info and dishing out the facts reagrding the frame numbers.
Blimey, the 250'sw/350's had I6's? Would there be a likely difference in the gearing between a C6 I6 trans and a C6 for the V8's?
Old Apr 6, 2009 | 04:54 PM
85e150's Avatar
85e150
C6 ratios are the same at 2.46, 1.46 and 1:1.
Shift points might be different, but could have been adjusted when installed in your truck. Will it rev out when you stand on it? Does the automatic downshift work properly?
addixionz
Sep 2, 2019 07:54 AM
mexbearlll
Feb 7, 2017 06:34 AM
yozsi
Jan 9, 2017 02:20 PM
frty7ford
Feb 17, 2016 12:50 PM
MikeB 88
1983 - 2012 Ranger & B-Series
Aug 21, 2014 06:00 PM
