Loose ipr?????
Old Mar 24, 2009 | 05:15 PM
lazerf250's Avatar
lazerf250
Question Loose ipr?????
I was checking my ipr and could tell it has had oil on it and i could move it side to side. Im pretty sure its not suppose to but not positive? What bolt tightns it up or to remove it???
Old Mar 24, 2009 | 05:26 PM
BlueMule's Avatar
BlueMule
The IPR is threaded and screws into the back of the HPOP,it has an o-ring at the base and it should be tight to keep it from leaking oil.
The coil is held onto the IPR by a sheetmatal nut.
Old Mar 24, 2009 | 05:32 PM
lazerf250's Avatar
lazerf250
ok so that nut at the end of the hpop farthest to the back is the one?? i didnt think it was suppose to move...it has a lot of slop left top right..
Old Mar 24, 2009 | 07:30 PM
plowhand's Avatar
plowhand
Playing in the Dirt
If you can move the coil left to right you need to snug up the Tinnerman Nut, (from Ford shop manual: Tighten nut to 6 N-m (53 lb-in)).
Old Mar 24, 2009 | 07:39 PM
lazerf250's Avatar
lazerf250
is that the one all the way to the back???
Old Mar 24, 2009 | 07:59 PM
plowhand's Avatar
plowhand
Playing in the Dirt
When looking over the HPOP reservoir towards the fuel filter housing, the IPR will be on your right hand side of the HPOP. The IPR solenoid has a black two wire connector on it and at the rear of the solenoid there will be a tinnerman nut (made out of sheet metal). This is the nut that hold the IPR solenoid on and tight.
cabloom300
Mar 22, 2019 10:00 AM
bigpimpin
Nov 29, 2013 10:12 PM
Squirrljam
Apr 6, 2012 09:06 PM
Rob_2T370
Jan 13, 2012 09:27 PM
GTRider
Dec 21, 2010 07:11 PM
