Ok...specifically those who know the 2004 6.0, is it possible to get the IPR out without taking out the turbo? The IPR is right behind the turbo. I do not see even having to take out the FICM to get to the IPR. I can see it after taking out the air hose to the turbo and pushing aside the wiring harness, but it's back there and somewhat behind the turbo. I had some instructions to go through the FICM side and not to take out the turbo..but..wouldn't be easier to just pluck out that turbo?
I have not picked it up yet...I was looking around for the best deal....
I did do some cleaning up in there to find where the whining sound was. It was a boot that was not fully pulled onto the turbo air pipe. That was when I was looking around to the best way to attack the IPR. I did not pull anything else apart, but will get as much pulled apart as possible. Let me know how you want to attack this.
Ryan I dont know where you was looking for an IPR but thought that I would post this for an 03 but its 180.00 from tousley ford might be some deals on E-Bay to IDK
IDK what one you have Im pretty shure there the same part only thing is the newer one the IPR Screen not so Fine from what I understand
You Guys Chime in if I am Wrong^^^^^^^
Heres the Ford & International part numbers
IPR (03-04 1/4) Without Edge Filter 3C3Z-9C968-AA 1839437C95
"IPR (04 1/2 - 07) With Edge Filter
NOTE: Tousley states ths is JUST for a 2007 MY" $250 5C3Z-9C968-CA 1846057C1
IPR screen 3C3Z-9H529-A
"IPR pigtail (to use to command the IPR valve closed)
for air testing the HPO system" 6E7Z-12A690-DA 1875204C91
Thanks Again!
Squirrljam,
Did you get my instructions on the removal and install of IPR? I PM'd it to you yesterday. Wish I could come out to help you and Benny but 1200 miles is too far for 1 day. If you did not get the instructs, I will send again in the morning. No turbo removal required.
Benny,
I checked e-bay last week-no ipr. $180 is a good price, I paid truck shop price in Miss and it was $231.
