Torque spec's
Mar 24, 2009 | 03:54 PM
Torque spec's
I need the torque settings for the caliper bolts and lug nuts for a 2006 F150 FX4, 18" wheels............Anybody?
Mar 24, 2009 | 04:13 PM
Not sure on the caliper bolts but the lug nuts are 150ft pounds
Mar 24, 2009 | 04:27 PM
Thank's, Josh. I'm setting them now. Calipers I usually set between 25 and 30 ft lbs. I'll leave them there unless I hear different.
Appreciate it, Jim
Mar 24, 2009 | 05:47 PM
Did a little more searching and found this.
Torque Specifications Description Nm lb-ft
Wheel nuts 204 150
Front Suspension
Wheel hub-to-wheel knuckle bolts 200 148
Tie-rod end nut 150 111
Front axle-to-wheel hub nut (4x4) 27 20
Upper ball joint nut 115 85
Upper arm-to-frame nuts 150 111
Lower ball joint nut 150 111
Lower arm-to-frame bolt and nut 300 222
Shock absorber upper mounting
plate-to-frame nuts (M10) 48 35
Shock absorber-to-lower arm
bolt and nut (M20) 475 351
Stabilizer bar bracket-to-frame bolts 48 35
Stabilizer bar-to-link nut 133 98
Stabilizer bar-to-link to
lower control arm nut 90 66
Anti-lock brake sensor bolt 18 13
Caliper anchor plate-to-wheel
Caliper-to-anchor plate bolts 32 24
Looks like the last one at 24ft pounds....so your 25 should be good!
Mar 24, 2009 | 05:59 PM
Thank's again. I redid the wheel nuts and I'll leave the calipers alone. Appreciate the info. It's printed and filed.
Jim
Mar 24, 2009 | 06:18 PM
Quote:
Originally Posted by
Ford Fx4
Shock absorber lower
And what are you going to get to torque that with....a gorrilla?
Mar 24, 2009 | 06:46 PM
At two hundred pounds the torque wrench clicks and the one you hear at 375 is your cajone's hittin' the garage floor.
Mar 24, 2009 | 07:41 PM
jcee
Guess thats why they invented torque sticks to use with your impact wrench! Gotta love the torquing power of a good Ingersol Rand impact wrench with a torque stick attached to it! Think Snap On still sells torque sticks. Don't think Sears Craftsman has them anymore.
Zazoos
Oct 6, 2016 06:04 PM
fatbs
Aug 16, 2016 10:39 AM
green_95
Jun 17, 2016 12:37 PM
bkuuz1
All Things Towing
Apr 19, 2016 07:14 PM
lvmoose007
Dec 5, 2002 11:05 AM
2004 ,
2006 ,
66 ,
arm ,
bar ,
bolt ,
caliper ,
f150 ,
ford ,
hub ,
lower ,
spec ,
specs ,
stabilizer ,
torque ,
truck ,
wheel
