Sous,
I'm not aware of it yet, either. I was looking at some systems online. I saw a couple of setups that would give you 4 readings to a display in the cab that you plugged into a charge port. I was thinking, if that was possible then maybe someone figured out a way to get a TPMS reading from a trailer on TP.
Torque pro will read the factory TPMS from the truck's computer. I guess in theory if you installed the sensors in the trailer's tires instead of the truck"s tires it would work if they aren't out of range. The dually's have the TPMS deleted but I wonder if you could activate it somehow??
