Torque
Old Aug 16, 2016 | 06:13 AM
fatbs's Avatar
fatbs
Torque
Where can i find the torque specs and order for the 1975 302 i am work on?
Old Aug 16, 2016 | 09:56 AM
CougarJohn's Avatar
CougarJohn
Small Block Ford Head Torque Sequence | GTSparkplugs
I think this is what you need.
Old Aug 16, 2016 | 10:39 AM
daveengelson's Avatar
daveengelson
Sorry, not computer literate, as a result massive pic's as opposed to links? These spec's are out of the Small-Block Ford 'how to rebuild book.
The values listed below are the spec's I used in reassembling my 68 (289-302) 8 years ago. Make sure to research the spec's meet your application!!
Timing Gear Cover: 12-15 ft.#'s
Oil Pump to Cyl: 12-15 ft.#'s
Pressure Plate to Flywheel: 25 ft.#'s
Damper to Crankshaft: 70-90 ft #'s
Flywheel to Crankshaft: 75-85 ft.#'s
Valve Covers: 3-5 ft.#'s
Pressure Plate to Flywheel: 20-25 ft.#'
Intake Manifold: 20-22 ft.#'s
Exhaust Manifold: 15-20 ft.#'s
Clutch Housing to Block: 40-50 ft.#'s
Clutch Housing to Trans: 35-40 ft.#'s
sere0501
Jan 31, 2018 05:38 PM
strokin'_tatsch
Sep 25, 2016 12:22 PM
malundquist
Jul 20, 2014 10:48 AM
DAVTruck
Sep 4, 2010 04:22 PM
rickgthf
Oct 21, 2006 04:43 AM
