Installing Guages
Old Mar 24, 2009 | 09:39 AM
notiones's Avatar
notiones
Installing Guages
I hope I am not the first one to ask this question. I couldn't find any relevant posts so it leads me to believe I am.
I purchased a isspro tri gauge kit, pyrometer, boost, and trans temp, but am not sure where to install the sensors. Nothing seems obvious.
Pyrometer: I still have the OEM downpipe and the sender is longer than the downpipe is thick!
Trans temp: I don't see anywhere to install the sender. There are a couple of plugs, but I didn't want o just pop one out.
Boost: Totally lost on this one. Surely I don't drill a hole in the turbo!
Any links or advice would be appreciated.
Old Mar 24, 2009 | 10:34 AM
mojoman's Avatar
mojoman
I'm no pro but I have researched a bit...pyro goes to left hand rear exhaust manifold....there is a flat spot at the end...drill and tap...tranny gauge hooks up on driverside pull the top plug I believe and connect there...boost goes to the hose for the MAP sensor....now don't go out and start hackin'...I've never done these yet....but my research points to these locations..someone will chime in with more experience than myself....hth
mojo
Old Mar 24, 2009 | 10:47 AM
notiones's Avatar
notiones
Trans-temp sender location
I believe this is the plug where the trans-temp sender gets installed. Someone correct me if I am wrong.
Still looking for the map sensor line and will check out the left rear of the manifold.
Thanks.
Old Mar 24, 2009 | 10:50 AM
mojoman's Avatar
mojoman
MAP sensor line should be passenger side firewall...
mojo
Old Mar 24, 2009 | 11:00 AM
TexasDiesel97's Avatar
TexasDiesel97
this thread should help
https://www.ford-trucks.com/forums/7...placement.html
notiones, correct on the trans temp sensor
Old Mar 24, 2009 | 11:22 AM
KevinC.'s Avatar
KevinC.
MAP line exits the passengers side intake manifold and travels to the firewall to plug into the MAP sensor.
Here is a link to pyrometer location - https://www.ford-trucks.com/forums/8...aust-temp.html
Old Mar 24, 2009 | 11:24 AM
notiones's Avatar
notiones
tee for boost gauge
Thanks for the link. Pics always help. I figured out where the map sensor line was shortly before you posted. Thank goodness for Alldata. Anyway, the link is great and answers the rest of my questions. Looks like I am good to go.
Old Mar 24, 2009 | 11:26 AM
KevinC.'s Avatar
KevinC.
Good luck!
Old Mar 24, 2009 | 12:10 PM
notiones's Avatar
notiones
A-Pillar Tri-Gauge Mount
Now all I have to do is find better a-pillar mount for the gauges. The one I bought is pretty close to worthless.
Old Mar 24, 2009 | 01:09 PM
mojoman's Avatar
mojoman
when I get around to gauges I wanna go with a dash mount above the radio...))
mojo
smithm31
Mar 24, 2015 05:21 PM
big ole ford
16
Mar 7, 2014 09:01 PM
Bolt-on
Nov 6, 2013 11:28 PM
jbounds
15
Mar 28, 2013 05:08 PM
Ratkat
Aug 9, 2008 12:55 AM
