Installing a pyrometer
Old Feb 27, 2014 | 06:38 PM
big ole ford's Avatar
big ole ford
I want to install a pyrometer on my 94 7.3 IDI turbo and have never done this before. Is there a place on the turbo or outlet pipe for the probe to screw in or will I have to remove the downpipe and have a bung welded in? Honestly the only thing I know about Installing a pyrometer is that it needs to be as close to the turbo as possible or it wont do any good and I figured I had best put one on since I turned up my fuel pressure a bit I really dont want to cook my engine. Thanks for any info you guys might have on this!
Old Feb 27, 2014 | 06:52 PM
southtexasidi's Avatar
southtexasidi
Some put theirs in the downpipe. I put mine in the middle of the drivers side exhaust manifold. You want to read EGT's as close to the piston as possible...because thats what you dont want to melt down.
Old Feb 27, 2014 | 07:05 PM
big ole ford
How did you install the probe into the manifold? I would assume you have drilled and tapped a hole or used a heli-coil but we all know what happens when we assume... Anyway I like the idea of putting it in the manifold I think that would be easier than removing the downpipe also. Any recommendations on the gauge, I was looking at the autometer#4344 but am certainly open to suggestions. Thanks!
Old Feb 27, 2014 | 08:17 PM
fordtruckman838's Avatar
fordtruckman838
The best spot is to drill and tap the exhaust manifold next to #8 cylinder. I have read that it will give the best reading..
I dont have any experience with autometer but they should be good. I have used Isspro on big rigs with good luck. I have a used isspro that was given to me to install on my 6.9 I just havent gotten to it yet.
Old Feb 27, 2014 | 10:14 PM
racer30's Avatar
racer30
I put Mine in the manifold on the boss directly opposite the Exhaust port on what would be the #2 cylinder on a Truck, But on my MH its #7 because I used the drivers side manifold on the other side for the MH application. Its best to get the temps from a single cylinder's Exhaust gasses. check out My pic's on flickr http://www.flickr.com/photos/racer30/10130488203/
Old Feb 27, 2014 | 10:58 PM
hairyboxnoogle's Avatar
hairyboxnoogle
On the 79 i just drilled and tapped the manifold through the fender well. But check the exhaust for an exsisting bung.
Old Feb 27, 2014 | 11:20 PM
racer30's Avatar
racer30
I drilled and taped it for 1/8 pipe thread. Its easy when you have it off the engine...Doing it in the Truck could be fun....
Old Mar 6, 2014 | 11:06 AM
waterdog40's Avatar
waterdog40
gauges?
Hi gentleman .... I see u were talking bout the boost install there gauge wonder have u ever found a bung on OEM exhaust? I want to do a 3 gauge ped on DS open for comments.... Thanks men...
Old Mar 6, 2014 | 05:10 PM
ottoparts's Avatar
ottoparts
I have a Hypermax Turbo and the piping already had a place for the the pryo
Old Mar 6, 2014 | 06:31 PM
tjc transport's Avatar
tjc transport
i ain't rite
the banks turbo assembly has a bung in the turbo pedestal. the stock ATS units do not.
when i put the pyrometer in my 02, i mounted it in the driver side exhaust manifold at the rear. it was very accessible from underneath with both the drill and the tap.
once the hole was drilled and tapped, i just screwed the adapter in, then the thermocouple into the adapter.
going on 6 years now and still solid in there.
Old Mar 6, 2014 | 06:32 PM
tjc transport
i ain't rite
actually a pyrometer is an exhaust temp gauge. the boost gauge goes to the intake hat.
damn rookies!!!
Old Mar 7, 2014 | 01:10 AM
waterdog40's Avatar
waterdog40
Thumbs up
damn rookies!!!
Thank man.....lol.... I will be looking into that.... yes rookie is me in the diesel section...lmao
Old Mar 7, 2014 | 08:45 AM
Chevy_Eater's Avatar
Chevy_Eater
My ATS has a bung in the exhaust outlet on the snail. From what I've read this is a dumb place to have it as the exhaust has had plenty of opportunity to cool by this point.
When I get a pyro I'm going to drill my exhaust manifold.
Old Mar 7, 2014 | 02:04 PM
Ford F834's Avatar
Ford F834
ATS 085 and ATS 088 had it there, and by "snail" you mean the odd exhaust housing casting, not the intake plenum (also frequently referred to as a "snail"). It is not a great location, but in all fairness it is the same as the banks kit since the up pipe pedestal slip fits into one side of that exhaust casting. The probe is still pre-turbo just above the joint in the up pipe. That said, it is still not nearly as good as a measurement from the manifold and if you use it just know the reading is low. The ATS 093/factory turbo had no provision for a probe.
Old Mar 7, 2014 | 02:15 PM
tjc transport
i ain't rite
i only saw less than a 50 degree difference with the thermocouple under the turbo on the hot side of the pedestal compared to being in the exhaust manifold.
