02 E4OD to 97
Old Mar 22, 2009 | 08:54 PM
effedup350's Avatar
effedup350
02 E4OD to 97
Hey guys.* I'm new here trying to help a buddy out with his F-350.* It is a 1997 and the tranny with 300k on it has met its maker.* I found an F-250 E4OD in the area.* The question for you guys is will it fit.
Any help would be greatly appreciated as I don’t want to be in possession of a transmission that does not fit.
Thanks,
Ryan
Old Mar 23, 2009 | 04:11 PM
Cuda_jim's Avatar
Cuda_jim
Welcome to FTE. you need to give us more info on the trans you want to swap.
Same year? ect ect.
The trans needs to be from a diesel...gassers won't work.
If it's 2wd then the tran will need a new output shaft, needs to be disassemble for that.
Old Mar 23, 2009 | 05:23 PM
jeep1947's Avatar
jeep1947
Jim when did they go to the 4R100 in the 250?
Old Mar 23, 2009 | 05:31 PM
Cuda_jim's Avatar
Cuda_jim
IIRC it was in 97 when the new body style was introduced..but don't quote me, the trannie gurus will set it straight.
Old Mar 23, 2009 | 09:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It was 1999 when the new body style was introduced and the E4OD was changed for the 4R100.
Old Mar 23, 2009 | 10:56 PM
glasseater's Avatar
glasseater
yup but the outer dimensions are the same i believe? everything about is the same except for some internal stuff right?
please correct this if i'm wrong i haven't heard any comparisons about these 2 transmissions in at least a year
Old Mar 24, 2009 | 06:26 AM
tjbeggs's Avatar
tjbeggs
Internals are a little different but the 4R has a input speed sensor and the soleniod pack has to be swapped out to fit the wiring harness. I not sure on this but the Trans Range sensor may be different and need to be swapped.
Old Mar 29, 2009 | 12:43 PM
effedup350's Avatar
effedup350
Thanks for all the replies. Turns out the source tranny was 2wd and the target is 4wd. From your help and the research I have done replacing the output shaft is above our skill level so he decided to buy another truck to replace this one. Thanks for all your help!
-Ryan
John Ken Howerton
Nov 3, 2016 10:28 AM
bart f-350
May 15, 2016 07:13 AM
Osiyo59
20
Aug 2, 2015 10:20 PM
lomac9
Ford Truck Parts for Sale
Mar 10, 2015 12:01 AM
mustangman
Oct 29, 2005 10:40 AM
