tranny problems
Old Mar 21, 2009 | 11:59 AM
Dan Taylor's Avatar
Dan Taylor
tranny problems
got a 1999 f250 7.3 with the auto tranny 20 bolt tranny pan. the transmision overheated the other day on the highway. ussually stays around 150 and it hit 180 and i pulled over then later on it went to 220 deg. just put all new fluid in and filter. just took it out and same thing happened. did i kill it?
Old Mar 21, 2009 | 11:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is it low on fluid? Is it overfilled? Either one will cause it to run hot.
Old Mar 22, 2009 | 07:06 PM
Dan Taylor's Avatar
Dan Taylor
the fluids are at the right level. i was just on the highway, looked at trans temp and said 125 deg. like 10 min later i took a quick look at it and it was at 220. from a cold start and running it takes about 15 min for it to get around 200 deg.
Old Mar 22, 2009 | 07:45 PM
guitarpicr's Avatar
guitarpicr
Dan -What brand of gauges do you have? I recently had a similar problem w/mine but mine was bouncing erratically. Diesel manor is sending me a new amp box for it.
Old Mar 22, 2009 | 08:53 PM
Dan Taylor's Avatar
Dan Taylor
i got a set of autometer gauges but they arent bouncing around or anything just a steady incline when running and wen i turn it off it does drop back down
Old Mar 23, 2009 | 03:42 PM
Dan Taylor's Avatar
Dan Taylor
tranny is gone. getting terrys transmission in CT to rebuild it. who wants to buy a dp tuner?
dieselsmoker
6.4L Power Stroke Diesel
Dec 18, 2011 07:00 AM
AJB201
Jul 6, 2011 01:54 PM
lonewolf777
Oil & Lubrication
Apr 20, 2011 04:33 PM
proudtruck
Jul 29, 2008 04:25 PM
aklim
18
Jun 14, 2006 03:35 PM
