Fuel filter/water separator?
Old Mar 23, 2009 | 09:41 AM
beanhead6D5's Avatar
beanhead6D5
I am working on doing a DIY reg.return and doing my own filter setup on the frame.
My question is does it matter if you put a reg. fuel filter before the pump or is it better to have a fuel/water separator before the pump and a reg. fuel filter after the pump?
Yes I know the fuel filter has to rated for pressure.
Old Mar 23, 2009 | 02:03 PM
nlemerise's Avatar
nlemerise
Brad, I put a Fleetguard FS1212 filter with a water stripper (petcock at bottom of the filter) before my pump. I also have the stock filter in place too...it always in perfect condition and no water in the housing at all. I change them both out, once a year.
Old Mar 23, 2009 | 02:19 PM
beanhead6D5
Thanks Neal!
I need to revise my question.
Does it matter if the fuel/water sep. goes after the pump?because my water sep. is for the pressure side.
So my setup will be,spin on fuel filter/fuel pump/fuel water sep./reg return.
I Didn't know if this would be the correct order or not.
Old Mar 23, 2009 | 02:28 PM
F250_'s Avatar
F250_
Brad... shouldn't matter which side, so I think your proposed setup would be fine. you've already covered the pressure rating for the post-pump filter, so that won't be an issue. I've read, though, that you should filter down to 2 microns if you're going to replace the stock filter/housing in the engine valley and the fuel rail port screens at the heads... that way you maintain protection for the injector internals.
Old Mar 23, 2009 | 03:35 PM
ron's power stroke's Avatar
ron's power stroke
it would be ideal to have the water seperator before the pump to protect the pump as well..but thats not real inportent ...it can be after the pump as long as it handles the 70PSI and filters down to 2 micron..i run the 1212 with water seperator Neal posted before the pump..I then crossed a 2 micron CAT filter part ## with napa for a fiter and base...i have that down on the frame right after the pump..
Old Mar 23, 2009 | 03:49 PM
beanhead6D5
Thanks guys!!
The water sep is rated at 100psi. and its a 2micron.and the pre filter is a 10m.
Ron,was the cat filter a 1R 0756? IIRC that was there 2micron filter.
Does it handle the pressure allright and not leak?
Old Mar 23, 2009 | 03:54 PM
ron's power stroke
cant remember the cat ## the napa filter is a 3528 that i use..that and the base are good for 100 psi also..no leaks at all....
Old Mar 23, 2009 | 03:57 PM
ron's power stroke
just found the invoice... the cat## is 1R0750 the base is napa#4770
the 1R0756 is the 6 micron filter
Old Mar 23, 2009 | 04:01 PM
beanhead6D5
Thanks Ron!!
I think I have the base allready,just have to get the filter now.That way I can put the water sep before the pump.
Bobbys Big Red Rig
Jun 20, 2017 08:55 PM
clueless70
Mar 20, 2017 03:52 PM
artfd
Jan 1, 2012 08:13 PM
ddb
Sep 27, 2005 03:27 PM
Jonboy
Feb 24, 2004 12:18 AM
