Sponsored by: Real Truck
Aftermarket backup camera
Old Mar 28, 2009 | 10:18 AM
  #76
Smackit's Avatar
Smackit
01 SD Reverse wire color for Camera
Anybody know what color this wire is and where underneath the dash it will be? I will be pulling off the tail light to try and track it but just seeing if anyone knows on here, read most of the post about the back up cameras and it has been pretty helpful just no wire color!
Old Mar 28, 2009 | 04:17 PM
  #77
wallz's Avatar
wallz
Are u looking to power up the monitor in reverse only? If just for power to camera splice into backup circuit behind the tail light.
If you want power to monitor always splice into hot always in the fuse box. I powered mine to turn on only when in reverse, and found it easier to splice under the hood. Not enough room under the dash to find the right wire. I ran thru firewall and to the bundle that runs to the underside, on the drivers side. On your truck it might be different, I have an 02 Excursion. I found the black/pink tracer. It will be the same color that you splice into behind the tail light. I have pictures in gallery if needed.
Old Mar 28, 2009 | 08:19 PM
  #78
Smackit's Avatar
Smackit
black w/pink stripe
Wallz - I would like it to come on when you put it in reverse, I found the black w/pink stripe behind the kick panel on the passenger side, I spliced into it but it still does not come, I am assuming it triggers power when it is in reverse, there is no power to this wire when it is in reverse. Where did you hook up to it under the hood?
Thanks again for your help!
Old Mar 28, 2009 | 08:37 PM
  #79
wallz's Avatar
wallz
Here are the pictures that I took, not very clear but hopefully they help. Under the hood, on drivers side is where the wires come thru the firewall. Under/beside the brake boost.
[IMG][/IMG]
[IMG][/IMG]
Old Apr 14, 2009 | 08:31 AM
  #80
67nukeford's Avatar
67nukeford
Veteran: Navy
Thought I'd bump this back up. Just recieved for my Bday a winplus back up camera kit,
Amazon.com: Winplus Wireless Back-up Camera System with 3.5" LCD Color Monitor: Automotive
with the license plate mount. I'll get this on this week, and let you guys know how well it works. I'll probably wire it up to work only in reverse.
Old Apr 15, 2009 | 02:57 AM
  #81
acertm's Avatar
acertm
Thanks to everyone providing this information. Just an idea about splicing into reverse light at tail light.
U-hall sells a tail light bulb with a pigtail attached so that you can run temporary lights to say to a car on a dolly. I seems that a person could run the pig tail out between the lense and the housing as intended and then tuck it around the out side of the housing so it is available in the fender behind the light. It provides a round bullet connector. this would preclude splicing into the wiring harness.
Just a thought.
Old Apr 15, 2009 | 07:32 AM
  #82
st8yd's Avatar
st8yd
nevermind........
Old Apr 15, 2009 | 07:50 AM
  #83
67nukeford's Avatar
67nukeford
Veteran: Navy
I think what I'm going to do, is have the camera hooked to the reverse lights, and have the monitor hooked up to one of the upfitter switches, that way I can just turn it on whenever I need it, since I may not need it every time I back up.
Old Apr 15, 2009 | 09:00 AM
  #84
Downriver Thunder's Avatar
Downriver Thunder
Unless you have a kid like my oldest that always wants to watch the cars behind us while driving down the road. lol
Old Apr 15, 2009 | 09:11 AM
  #85
67nukeford's Avatar
67nukeford
Veteran: Navy
Heehee... I don't know if my daughter would be able to see it around my big head!!LOL!
Old Apr 15, 2009 | 10:01 AM
  #86
bpounds's Avatar
bpounds
I already have auxilliary backup lights wired to an upfitter. I was thinking of wiring the reverse camera to those, so I could turn the lights and camera on at any time, even if not in reverse.
Old Apr 15, 2009 | 10:02 AM
  #87
67nukeford's Avatar
67nukeford
Veteran: Navy
That's another thing I want to get, is aux. back up lights. It would be nice to have some more light backing the boat in the drive way at night. What did you install for those Bill?
Old Apr 15, 2009 | 10:05 AM
  #88
bpounds's Avatar
bpounds
I did the bearhunter style recently. Here are some photos:
https://www.ford-trucks.com/forums/s...&postcount=238
Old Apr 15, 2009 | 10:09 AM
  #89
67nukeford's Avatar
67nukeford
Veteran: Navy
Man, those are small! But they fit really well above your hitch. I was considering one of the sets that fit around the reciever. Or, a set below the bumper. I don't do much (or any, for that matter) off roading, so if they hung down a bit, that would be okay. Then again, I don't need huge ones either.
Old Apr 15, 2009 | 10:13 AM
  #90
bpounds's Avatar
bpounds
I haven't had much chance to use them yet. Outdoors season is starting at the end of the month, so I'll get a chance to test them more. I think they will be pretty good once I get away from city lights.
