Sponsored by: Real Truck
Aftermarket backup camera
Old Mar 19, 2009 | 02:49 PM
  #31
bpounds's Avatar
bpounds
Here is another one:
https://www.geekbro.com/index.cfm/hu...Back-Up-Camera
I'm in the same situation. I would like a GPS, and I would like a BU camera, and don't want to spend $1k for an in-dash unit. But I also want a really good GPS. The Nextar and 4UCAM brands would be a gamble. Why don't you buy first, and then let me know?
Old Mar 19, 2009 | 03:11 PM
  #32
67nukeford's Avatar
67nukeford
Veteran: Navy
I already have a GPS, so I just need the camera, but that would be the way to go if you didn't have GPS already!
Old Mar 19, 2009 | 10:34 PM
  #33
wallz's Avatar
wallz
I have added a wireless backup camera to my excursion and would have to say it is wonderfull. I have the one like the winplus. very easy to hook up, has the night vision, and only blurs slightly when turning on during reverse. I have it mounted just above the rear view mirror, (because that is were u look to back up) and have it wired to turn on when I put shift lever into reverse. It also has a second video input so u could use a second camera at the back of the trailer. I have no need for one so haven't looked for one but suppose you could get a hold of a wired one from fleebay. Simple button on monitor to switch to second source. Makes parking these beasts a lot easier in tight spots.
Old Mar 20, 2009 | 07:17 AM
  #34
67nukeford's Avatar
67nukeford
Veteran: Navy
Thanks for the info!!
Old Mar 20, 2009 | 08:58 AM
  #35
Downriver Thunder's Avatar
Downriver Thunder
Originally Posted by 97nukeford
No kidding? I was at Lemoore Ca, VA-122, AMS/3, 85-89! Tried to get orders down to Miramar, but couldn't, so I got out.
Out of A school Miramar was my first pick, second was Barber's Point, Hawaii. I wanted to be where Top Gun was. In fact, my squadron's hanger was the one from the movie where "Fightertown USA" was painted on.
Old Mar 20, 2009 | 09:23 AM
  #36
bpounds's Avatar
bpounds
wallz, is yours the Winplus like the one on Amazon? Or are you just saying yours is a similar wireless? If you could give a little more info about your model I would appreciate it.
This is the Amazon unit:
Amazon.com: Winplus Wireless Back-up Camera System with 3.5" LCD Color Monitor: Automotive
Dang Pat, you got me lusting for another gadget.
Old Mar 20, 2009 | 09:26 AM
  #37
67nukeford's Avatar
67nukeford
Veteran: Navy
I'm trying to figure out a good one for the wife to get me for my upcoming b-day Bill!
Old Mar 20, 2009 | 09:27 AM
  #38
67nukeford's Avatar
67nukeford
Veteran: Navy
I had second pick of orders out of "A" school, but most were either P-3's (which I didn't want) or A-7's at Lemoore.
Old Mar 20, 2009 | 08:37 PM
  #39
wallz's Avatar
wallz
[quote=bpounds;7285338]wallz, is yours the Winplus like the one on Amazon? Or are you just saying yours is a similar wireless? If you could give a little more info about your model I would appreciate it.
Packaging is different, but it is the winplus brand. (up in Canada so everything is different)
All of the mounting options they sent didn't work for my books, so I just zip tied loosely to the wiring running to the rear view mirror. Has inferred so it works nicely at night even with stock backup lights.
Old Mar 21, 2009 | 06:46 AM
  #40
high ho silver's Avatar
high ho silver
If you only need something for hooking up a trailer and not parking...here is another solution that is much quicker to install and a lot cheaper and its removable. I got one from Overton's.
Couple Mate - Trailers, Trailer Hitches, Trailer Parts, Trailering
Old Mar 21, 2009 | 08:02 AM
  #41
Downriver Thunder
How did you fasten the monitor above your mirror like that? I would like to put mine in the same place. My GPS & XM Roady take up my open spots right now.
[quote=wallz;7287545]
Old Mar 21, 2009 | 12:20 PM
  #42
wallz's Avatar
wallz
Downriver: here ya go. I hope you can see in the picture. Kinda zip tied loosely through the monitor to the wire.
Old Mar 21, 2009 | 12:33 PM
  #43
bpounds's Avatar
bpounds
Thanks for the added info, wallz. Simple - effective.
Old Mar 21, 2009 | 02:57 PM
  #44
sfgiantsfan9's Avatar
sfgiantsfan9
I use one that is built into the license plate frame made by a company called Boyo. It works REALLY good. Mine is ran off my dvd screen but they make one that comes with a screen as well.
Old Mar 21, 2009 | 09:08 PM
  #45
mrsdbro's Avatar
mrsdbro
I installed one that mounts on the license plate , but it sits too low for lining up the trailer. it's good for side to side alignment but you can't see the depth. you need it up high thats why ford put it in the tailgate handle. mine is mounted on my ARE lid just under the handle for openning. I'm at least now 90% at lining it up, saves alot of jumping in & out. I got off e-bay a 5.5" monitor and mounted it in the little door with the plastic cup (junk bin), the cup comes off easily enough. I just drop the door down and flip the switch on and I can see it all. It's great when backing into tight spots you can put the truck right up to the vehicle or whatever to within an inch. I'll post some pics tomorrow.
