I know the real test will be in the winter time with the road salt but I will let you know. If vibration and bumps kill the camera then this truck will do a good test.
Mine has stood the test of one winter with no problems. The only thing you do have to once in a while wipe off the road grime to be able to see clearly. Also nice to be able to park in town, especially in tight spots. Also nice to entertain onlookers that do not see that you have a backup camera and they watch to see you back into someones bumper. Makes them think that you are impressive with that big truck. http://images.ford-trucks.com/forums...ssingteeth.gif LOL I guess tho we are.
I was thinking maybe taking mine off in the winter, since I would mainly use it for the boat trailer.
See, mine is mainly for winter. I needed it to help with backing up in tight areas in our parking lot while plowing. Here is a pic of what I quickly came up with at lunch time. The bracket minus suction cup is zip tied to the cup holder I don't use. Nuke, I would wait on getting one of this model as I am not impressed with it. I don't know if it's a reception issue or either a bad power cord and/or socket on the monitor itself, I got alot of static while driving. I wiggled the plug on the monitor and got alot of static and it even blanked out a few times but not 100% sure if that was it. Over the weekend I am going to reattach the power to a constant 12v from my parking lights and move the wireless sending unit closer to the cab to see if that helps. Right now it's zip tied to the frame near the hitch. If it doesn't help then I am going to order a new one Monday from our tool supplier and swap the cord and monitor out.
On the plus side, when it was working right the picture was crystal clear and the range was excellent.
I need to come up with a power board too. I have my GPS and my DVD players that plug in on the dash, now I have a 4th unit with the camera. I wish I had a power point in the rear seat.
I guess I was stupid in thinking a "wireless" backup camera would actually be wireless. I spent a good hour on mine running the wire from the camera to the little transmitter. I put my transmitter inside the cab under the back seat to keep it out of the elements.
What brand do you have, and how well has it worked for you?
It's a Peak. Mine is also a little fuzzy while driving but then again it's not supposed to be on while driving. The instructions has you hook to the reverse lights but I have mine wired into a keyed power fuse under the dash.
Backing up or driving down the road didn't matter for mine. I understand that they are meant for simple backing up but while I was on I75 the picture was clear except for the moments it went staticy.
