I ran across a write-up on pullling the engine (should of bookmarked it). It was pretty funny. It involved good details, a nagging wife and step by step when to drink beer. I think I saw it here so maybe somebody has the link.
I should put these in my sig. Oh I forgot obnoxious ones are not aloud!!!!!!!!!
You will be lucky to get more than a few thousand miles on the engine with forged rods, and a crank balanced for Powdered metal rods. They are different weight rods, and if you don't rebalance, you're going to rip that motor apart over time, it's not a matter of RPM.
Youre also going to need a new complete gasket kit, including head gaskets. It's also a good idea while you are in there to put on a new oil pan and dipstick, new main and rod bearings, you'll need rod bearings anyway since the rods are different sized, not by much, but you are going to get shadetree results if you use shadetree techniques. Do it right the first time, or be like me and have to do it again. Not fun
Please correct me if i'm wrong by all means, but in my situation I dont think I will need to have the crank balanced, I understand that the rods are of different weight, but if all of the rods are matched weight to 1000th of a gram I dont quite see the need to rebalance. Again, correct me if i'm wrong.
And on your second paragraph, i've got a good friend at the ford dealer talking care of getting those things.
Yeah man listen to Kris he has been thru all this before more then a couple of times to say the least. We could just take a week off and drive that way .
you either need to remove or add weight on the counterweights of the CRANKSHAFT to match the weight of the rods swinging on the other end of the crankshaft
Dad for some reason doesnt want to sell it, sorry man. I thought he would, because I know how he is, I know it will just sit there in the way untill it rusts to nothing so idk man
No problem man. Give me a yell if he changes his mind.
Geezz man, what happened to make you have to do it 3 times?
I'm thinking along the same lines as you, with a couple of other people around, you would be surprised how much time can be saved from someone else passing you a wrench and not having to climb down, or out from under something.
The other reason why I think its better to have others there is as you mentioned, checking and rechecking, then someone else check and recheck me.
Well here is how it started off in July.. My truck is a 2002 so I have PMR's..
Passenger side of block
Drivers side
Parts found on the road
So then I get a forged rod block as a replacement and install it. I get a massive oil leak on initial start up. After looking further for the source of the leak. I find its on the front cover, which of course the only way to fix was to change the front cover which requires engine removal
After removing the engine, replacing the front cover and re installation of engine, it ran great....... for about 3 months
then this happens
So now I had a complete rebuild with lots of upgraded parts and This is what I installed last week and am happy to say my truck is running again!
Sheet, man i woulda put some JB weld or had someone MIG weld some aluminum bead right there at the crack. At least it would have been an option, not like you were going to ***** it up any more. lol
but yeah i know the feeling, im a window member too :
