Next mod ?
Old Mar 11, 2009 | 06:27 PM
mjtpolice76's Avatar
mjtpolice76
Next mod ?
So far I have done 4" exhaust, 6637 intake with Petes cover, DP tuner, guages, 203 thermostat, coolant filter. What should my next mod be for more power. I plan on changing all my silicone intake boots and pressure test them to make sure there are no leaks before my next mod.
Old Mar 11, 2009 | 06:34 PM
ron's power stroke's Avatar
ron's power stroke
ccv mod to keep the IC pipes and boots clean.. zoodad to get cold fresh air to the 6637 filter.. and for power ..the IDM mod can help you out there..and the WW or ATS housing to stop surge,,,
Old Mar 11, 2009 | 07:06 PM
beanhead6D5's Avatar
beanhead6D5
High pressure cross over line(HPX),fuel tank mods(Welcome to guzzle's In-tank Hutch Mod Web Page) ,cold a/c mod,reg.fuel return,and on and on and......
Old Mar 11, 2009 | 07:47 PM
guitarpicr's Avatar
guitarpicr
Nothing to do w/ power but what about a valve body in the trans assuming it's an auto. Sure will shift better.
Old Mar 11, 2009 | 07:55 PM
Bigcat350's Avatar
Bigcat350
Looks like you would be looking at some injectors soon. Lets spend some MONEY
Old Mar 11, 2009 | 07:58 PM
mjtpolice76
What's the cold ac mod
Old Mar 11, 2009 | 08:12 PM
03F2507.3's Avatar
03F2507.3
dieselsite.com
cold rush a/c
A MUST!!!!
Old Mar 11, 2009 | 10:59 PM
Gcrop's Avatar
Gcrop
I was actually going to post something similar.
I am more curious about mods for MPG though. Other than the intake/exhaust/DP Tuner I mean. Wasn't really sure what the "next step" is.
Old Mar 12, 2009 | 08:26 AM
sflem849's Avatar
sflem849
I am with Ron et al. Go for the cheap and easy mods next! You never mentioned doing the OBA, WW, CCV, In Tanks, HPX. I would CERTAINLY invest some money in a valve body if you have an auto. That is money very well spent.
You can do the cold a/c mod without the fancy kit by just putting a valve in the line going into the heater core. Semis have been doing it forever. That would be less than $20 worth of parts. How often do you go from heat to ac in one day anyhow??? The only down side to either kit is that it does not allow you to adjust the air temp coming out. We won't care, but our wives/women will!
Now I have to go search IDM mod...I forgot what that one was!
caddy
6.4L Power Stroke Diesel
13
Jun 24, 2013 05:30 AM
rayezra
Oct 25, 2009 06:24 AM
BillyBob69
30
Jun 12, 2009 09:05 PM
whiteaddiction
15
Sep 5, 2007 08:16 AM
Hotwheelbill
Apr 18, 2006 09:44 PM
