Water Pump Leak
Old Mar 11, 2009 | 08:32 AM
throwdown's Avatar
throwdown
Water Pump Leak
OK, I notice a coolant leak on the driveway. It seems to be the water pump. As it is winter in Ontario, ( I don't have a shop), I take it to a local shop to confirm water pump leak and repair cost. Shop confirms water pump needs replaced and gives me a price. 50% markup on parts alone. I pressure wash the pump and surrounding area and no leak since. What gives.
Waiting on 203 t-stat and billit housing before the repair is done. Also adding ELC and bypass filter.
Any ideas why it would just stop leaking. I will err on the side of caution.
Old Mar 11, 2009 | 09:30 AM
megawatt00's Avatar
megawatt00
Maybe some "crud" in the system that is plugging the hole up? I'd keep a close eye on it though.
Old Mar 11, 2009 | 09:32 AM
throwdown's Avatar
throwdown
I'll replace when my t-stat gets here. The bypass filter should help with the crud.
Thanks
Old Mar 11, 2009 | 09:35 AM
DieselCamper01's Avatar
DieselCamper01
I wonder if it was the pump or the hose on the pump. Maybe pressure washing moved the hose just enough to reform a seal? Just a wild a** guess.
Old Mar 11, 2009 | 09:37 AM
throwdown's Avatar
throwdown
Maybe a closer inspection is in order. Nasty weather out in my driveway though.
Old Mar 11, 2009 | 09:44 AM
distortedcloud's Avatar
distortedcloud
When its better out for you, take the belt off and give the fan blades a wiggle....it shouldn't move. If it did, its probably a bearing went out and the pump needs to be replaced.
Also with these pumps, they have a weep hole for when the seals/bearings go, it will leak indicating its time to replace it.
Old Mar 11, 2009 | 09:47 AM
throwdown's Avatar
throwdown
I'll do that. Thanks
Old Mar 11, 2009 | 09:51 AM
vettdvr's Avatar
vettdvr
The pump is bad. The seal is failing and at times might not leak. Remember it heats and cools. Change the pump, belts, hoses, thermostat. I just completed mine in the last 3000 miles fortunately I have a shop and a TOPSIDE CREEPER.
Old Mar 11, 2009 | 10:15 AM
throwdown's Avatar
throwdown
That's the best I think, after all, it has 258,000 kilometers on all those parts.
Thanks for the input
Old Mar 11, 2009 | 11:51 AM
only90s's Avatar
only90s
+1...I actually just replaced mine and that is what it was doing....the heating and cooling effected when it leaked; however once it was removed the bearing was junk anyway...
I would get a new filler neck as well.
Old Mar 11, 2009 | 12:18 PM
throwdown's Avatar
throwdown
Hate to appear stupid---what do you mean by filler neck?
Old Mar 11, 2009 | 12:24 PM
whjco's Avatar
whjco
Good suggestion! I also replaced my serpentine belt, idler pulley and belt tensioner while I was in there.
What's a topside creeper? Sounds interesting!
Old Mar 11, 2009 | 03:39 PM
Supercab's Avatar
Supercab
Wink
Best pump to get is from AIRTEX, Notthern tool, they sell on Ebay, BRAND NEW pump, do not waste your time to install a reman pump, and I would strongly suggest using a thermostat "O" ring on the lower water pump coupler from the begining as it is thicker and will seal better, I installed a new Airtex pump and the lower pipe coupler leaked after only 3 months.
A topside creeper is just that its formed so you are on top of the engine not under it, someone here may have a picture....
Old Mar 11, 2009 | 04:01 PM
vettdvr's Avatar
vettdvr
Do a search for topside creeper. Don't have a pic but basically you are flat over the engine on a creeper vs kneeling on the radiator with your back bent.
Old Mar 11, 2009 | 04:04 PM
only90s's Avatar
only90s
mabye I am calling it the wrong thing...where the hose attaches to the water pump...ie thermostat housing maybe?
