about egt numbers
Old Mar 11, 2009 | 08:07 AM
fordguy712's Avatar
fordguy712
Question about egt numbers
lately my truck has been running weird i start up driving my egt's will be around 300 then by 4th gear they will drop to near nothing on the gauge. could this be a fried turbo?
Old Mar 11, 2009 | 08:25 AM
Cuda_jim's Avatar
Cuda_jim
Sounds like the gauge is messed up since you didn't mention a loss of power. If the turbo was fried you notice the loss.
Old Mar 11, 2009 | 10:08 AM
stephen.south's Avatar
stephen.south
even if your turbo was bad the temps would still be up, it's the enginge and fuel that produces the heat
Old Mar 11, 2009 | 01:36 PM
884x4broncoII's Avatar
884x4broncoII
if the turbo was shot the egt's would probably go up not down, i would say its a problem in the gauge
Old Mar 11, 2009 | 03:19 PM
Cuda_jim's Avatar
Cuda_jim
Maybe I got this all wrong but....
Bad turbo = Low boost
Low boost = Less fuel
Less fuel = low EGT's Which is = to Low power
That's why I asked if it was down on power.
Old Mar 11, 2009 | 06:40 PM
FARM69's Avatar
FARM69
Cuda, I think it's the other way around because the low readings from the MAP sensor would make it go into the default setting?
Without the charger your temps would be awfully high I'd imagine.
Old Mar 11, 2009 | 07:46 PM
fordguy712's Avatar
fordguy712
thanks guys i'll look into the gauge tomorrow you guys really help out alot
Old Mar 11, 2009 | 08:50 PM
Oversize's Avatar
Oversize
On my road tractors if they lose the turbo the power drops like a rock you usually will have a lot of white smoke (excess unburned fuel, due to not enough air in the mix) and the temps will be about the same or less as it its burning all the fuel. Id agree though its the gauge.
Old Mar 12, 2009 | 08:40 AM
Cuda_jim's Avatar
Cuda_jim
Like I said, could be wrong...the amount of fuel increases with the boost readings from the MAP. The MAP only goes into default when the MAP is bad not from a low boost readings. I never notices the EGT's when there was a MAP or a Boost issue.
Does your OTR truck have the same system as the PSD? HEUI style injection and a MAP.
jayhawk714
Feb 12, 2017 04:35 PM
HowieE
Nov 10, 2016 06:15 PM
dmanshane
39
Nov 23, 2014 01:25 AM
mudddogg69
Jun 25, 2013 09:02 AM
CPUNeck
28
Apr 7, 2010 07:21 PM
