U Bolts on Front
Old Mar 11, 2009 | 07:39 PM
JethroF250's Avatar
JethroF250
U Bolts on Front
i think i'm doin my leveling kit this weekend. is there torque specs for the u bolts on the springs? and will the stock u bolts work?
Old Mar 11, 2009 | 07:46 PM
pjwoolw's Avatar
pjwoolw
Probably shouldn't use the old u-bolts. What kit? Below is what I have for the 97.
TORQUE SPECIFICATIONS
Front
Front Spring to Axle U-Bolt 113-153 Nm (83-113 ft. lbs.)
Front Spring Shackle to Frame 170-230 Nm (125-170 ft. lbs.)
Front Spring to Shackle 149-201 Nm (110-148 ft. lbs.)
Rear
Leaf Spring-to-Axle U-Bolt Nut 192-258 Nm (142-190 ft. lbs.)
Leaf Spring-to-Front Bracket Nut and Bolt 192-258 Nm (142-190 ft. lbs.)
Leaf Spring-to-Rear Shackle Nut and Bolt 113-153 Nm (83-113 ft. lbs.)
Rear Shackle-to-Frame Nut and Bolt 77-103 Nm (57-75 ft. lbs.)
Old Mar 11, 2009 | 08:38 PM
Oversize's Avatar
Oversize
You really cant reuse u bolts and trust them theve been stressed and wont properly torque properly. I d replace them, dont forget to recheck the torques after acouple hundred miles about 4 times as the bolts will stretch some.
Old Mar 11, 2009 | 08:48 PM
97biostroke's Avatar
97biostroke
Gettin the u-bolts off can be quite fun. Mine wouldnt go with a good impact gun, so i put the "hot wrench" on em. Took all of 3 minutes to get em all off with a good torch.
Old Mar 11, 2009 | 08:53 PM
Oversize's Avatar
Oversize
That or a die grinder with a cut off wheel works great too. just zip through em, but if your gonna try to unscrew em be prepared for fun they're usually rusted on and the threads arent usually in too good of condition, yet another reason not to try to reuse them. Good luck.
Old Mar 11, 2009 | 08:59 PM
tjbeggs's Avatar
tjbeggs
I've reused lots of u-bolts. Never and issue. Crank them down with a good 1/2 impact till they won't move any more. Then recheck them in a few days.
Old Mar 11, 2009 | 09:49 PM
FARM69's Avatar
FARM69
I reused my u-bolts when I added leafs to the front. I didn't have any problems getting them loose with a 3/4 inch impact. I tightened them down and confirmed them after a few hundred miles as well.
Plasma torch works wonders on old stubborn rusted bolts. We never get the ol hot wrench out unless we need to salvage/reuse.
Old Mar 12, 2009 | 11:10 AM
JethroF250's Avatar
JethroF250
ok thanks for your opinions guys
53FOPAR
17
Sep 12, 2018 03:59 PM
BigBlueX
Feb 3, 2016 03:34 PM
speedcostsmoney
Dec 23, 2013 04:55 AM
jeffsonday
Jan 28, 2011 12:17 PM
VQ2Fast4U
Oct 19, 2007 12:45 PM
