changing tranny fluid need advice
Old Mar 10, 2009 | 05:49 PM
jayram75's Avatar
jayram75
Hi again im changing my tranny fluid in my 2000 expy 4wd with the 4r100 tranny with the plug in the pan and was told by somone to take out the plug in the converter too and drain that. my quest is if i do that will the pump in the tranny fill the converter back up. Ive never drained one that way and am not sure. thanx for looking!
Old Mar 10, 2009 | 09:36 PM
alloro's Avatar
alloro
Yes, the pump will fill the converter back up. Just keep in mind that the fluid in the pan will get sucked out real fast as the converter gets filled up. So keep a good eye on your fluid level.
Old Mar 11, 2009 | 10:03 AM
KR1's Avatar
KR1
Must be nice to have a tranny pan plug.... A tranny fluid bath, and or slow draining is no fun.. I need to add a drain plug next time. I assume that there is not one there, since it may lead to drain and refill only.
I recently drained, new filter, drained the TC, and added about half capacity and let it run a few minutes and then added more to bring the level up.
Old Mar 11, 2009 | 02:28 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
There are plenty of threads and many strong opinions as to how best to handle a tranny fluid change. You may consider doing a search to get more info. But it sounds like you know what your doing. Most of us would love to have a transmission drain plug.
Tim
Old Mar 12, 2009 | 08:17 PM
jayram75's Avatar
jayram75
thanx guys Im doin it this weekend!!
Old Mar 12, 2009 | 09:48 PM
Rob_C's Avatar
Rob_C
Anybody got a link or source of supply for a tranny drain plug?
Old Mar 12, 2009 | 11:07 PM
alloro's Avatar
alloro
Your local auto parts store should have them. If not, get one here:
Dorman Motormite 65241 Clutch Components, Transmission Hardware - OutdoorPros.com
Old Mar 13, 2009 | 09:47 AM
Rob_C's Avatar
Rob_C
Thanks for the source!
Old Mar 13, 2009 | 10:47 PM
cecoen's Avatar
cecoen
Hello all,
I am about to do my first tranny fluid change also and was thinking back to my '02 F150 4x4 supercrew lariat. It had a drain bolt on the torque converter (if I am remembering correctly) but my '01 and my '03 did not. I now drive an '04 expy xlt 4.6 2x4 (I know, I know...I just couldn't afford the 4x4!) anyway, I was wanting to do the full monty fluid change and was wondering if anyone knows if my expy has the drain on the torque converter? I THINK it has pretty much the same 4r70w (or something like that) tranny as my f150's, isn't it? If not, should I just pony up and pay Ford to power flush all the fluid out? I just hit 40K miles and should have done this 10K ago but work, family, blah, blah, blah....
Thanks,
Chad
jagarcia89
2004 - 2008 F150
May 4, 2012 01:08 PM
05ExcursionLTD
Jun 19, 2009 07:15 AM
Groundpounder0331
May 18, 2009 09:22 AM
quick35th
Nov 25, 2005 07:49 PM
omni
Jul 1, 2004 12:56 AM
