hpop overdrive
Old Mar 13, 2009 | 06:32 AM
Neal 97 250's Avatar
Neal 97 250
Originally Posted by tjbeggs
Cold should not be an issue.
That is good to know.
Good question though.
Old Mar 13, 2009 | 11:16 AM
Talyn's Avatar
Talyn
I don't get why you have to switch to electric fuel, but I did not read the article.
I would think it was some replacement parts for the pump to allow more volume though on the pump.
*shrugs*
Old Mar 13, 2009 | 11:22 AM
tjbeggs's Avatar
tjbeggs
The od unit is a bolt unit between the engine and hpop so crowds the fuel canister out of it home
Old Mar 13, 2009 | 11:24 AM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
the overdrive will not be able to be installed with the stock fuel bowl in the way, hence needing at least a remote fuel filter, and at that pount, you might as well go to electric fuel if you're going to be running injectors big enough to have the need for the overdrive in the first place.
Old Mar 13, 2009 | 11:29 AM
Talyn's Avatar
Talyn
Well that makes sense.
I would probably up my HPOP even with stock injectors. *shrugs*
Sledhead3
18
Mar 1, 2017 08:57 PM
hydell3
Sep 23, 2016 11:50 AM
tbax46
Jul 23, 2016 11:13 PM
Dieselgrowl
17
Aug 9, 2013 09:00 AM
wburge
Jun 15, 2010 09:35 PM
