Bad hpop???
Old Sep 21, 2016 | 06:00 PM
hydell3's Avatar
hydell3
Bad hpop???
So I had hard start issues. Then no start. The hpop is empty. I filled it and tried to start, still nothing. I even tried leaving the plug out and cranking to see if it'd blow out oil, nothing. So is my hpop bad??.
Old Sep 21, 2016 | 06:12 PM
The Brad's Avatar
The Brad
That sound more like either low oil level, or a bad LPOP. If you oil level is good, overfill the oil pan by about a quart and jack up the rear end. If that works, you might have a broken oil pickup.
Old Sep 21, 2016 | 06:21 PM
hydell3's Avatar
hydell3
See the pan level is the first thing I check, I didn't over fill it but I can add some more. But shouldn't filling up the hpop itself give me something? I'd think with it being filled up when I crank the motor oil should blow out the check hole shouldn't it?
Old Sep 21, 2016 | 07:08 PM
The Brad's Avatar
The Brad
If the HPOP reservoir was empty, it probably pumped air into the HPO rails, so it's gonna take some cranking to build pressure. The HPOP takes the oil from the reservoir and sends it to the injectors. It's the LPOP that takes the oil from the pan to the HPOP reservoir. The only reasons for an empty HPOP reservoir are either a leaking check ball allowing the oil to drain back down to the pan, or a problem in the LP oil system not sending the oil up to the HPOP.
Your first mission is to get oil pressure to the HPOP reservoir. To do that, you'll need to overfill the pan and jack the rear end up. Doing this submerges the pickup tube where they're known to leak. If that doesn't work, then your LPOP is probably bad. Here's a video I made while checking my last no start issue:
Old Sep 21, 2016 | 07:15 PM
F350-6's Avatar
F350-6
If no oil comes out when you remove the plug from the HPOP reservoir, then the motor is not pumping oil to the HPOP. Either a bad LPOP (rare it doesn't pump anything), or a cracked pick up tube not able to pull oil out of the pan, or not enough oil in the pan to pump.
A bad HPOP will still pump oil, just not at the required volume. It will also allow oil to make a complete mess of things if the plug in the reservoir is removed.
Old Sep 21, 2016 | 11:12 PM
timmyboy76's Avatar
timmyboy76
With resivoir plug out, I'd think the lpop would make the mess, not the hpop, considering, the "oil pressure" sender is located in same place. No oil fountaining, no low oil pressure
Old Sep 22, 2016 | 08:06 AM
hydell3's Avatar
hydell3
Alright I'm going to try the over filling and lifting the rear end and see where that gets me. Another thing though. I was having a decent amount of white smoke. And some oil in the exhaust, does that automatically mean bad rings? Might be a stupid question but I'm not a diesel mechanic, I know with a gas motor I'd be rebuilding it.
Old Sep 22, 2016 | 07:39 PM
F350-6's Avatar
F350-6
White smoke just means something's burning. Could be fuel from poor combustion or oil leaking into the turbo. Usually not an indicator for a rebuild if it just started happening.
Old Sep 22, 2016 | 10:06 PM
hydell3's Avatar
hydell3
Its been doing it for awhile. I rebuilt the turbo but I guess it's possible I didn't get everything sealed right or is there somewhere else I didn't know about that oil can leak into it. It'll shoot a good amount of oil by it. I have a good stack and it'll have a decent amount in it.
Old Sep 23, 2016 | 11:50 AM
knottyrope's Avatar
knottyrope
Oil will be burned in the cylinder unless there is low compression on a cylinder/s
oil in exhaust pipe can be from the fuel unburnt or turbo seal leak
JetFuelBurner
Jan 9, 2013 05:58 PM
BigTruk small feet
Apr 24, 2012 11:01 AM
90pioneer
Jun 27, 2011 06:03 PM
Nick_S
1978 - 1996 Big Bronco
Feb 3, 2011 02:47 PM
th67ss
19
Oct 7, 2010 01:09 AM
