Sponsored by: Real Truck
dual exhaust?
Old Mar 4, 2009 | 05:33 PM
JakeShell's Avatar
JakeShell
dual exhaust?
just bought '03 F250 super duty and im looking to put dual exhaust on. i would like to run it from 2 separate cat's. what would be the best way of doing this with mid-range pricing?
Old Mar 4, 2009 | 09:29 PM
Furian's Avatar
Furian
You Keep What You Kill
We need a little more information before we can respond to your question. What engine do you have? Are you wanting to replace the OEM cats with high-flow cats? What do you consider to be "mid-range" in terms of cost?
Welcome to FTE!
Old Mar 6, 2009 | 05:14 PM
JakeShell's Avatar
JakeShell
engine
Welcome to FTE!
engine is a 5.4L V8
i would like to replace the cat with the high flow cats but if thats a problem i can do without
as far as mid level pricing somewhere between $300 and $400
Old Mar 6, 2009 | 06:07 PM
Lubbockguy1979's Avatar
Lubbockguy1979
i wouldnt run a true dual exaust. i would run a x pipe or h pipe system. i would also find some cats or get new cats and gut them
Old Mar 7, 2009 | 04:14 AM
Furian's Avatar
Furian
Based on your profile, you have low miles on your truck so I would not replace the cats. The Gen1 (1999-2004) Super Duties had a very restrictive Y-pipe that narrowed down to around 1.5" at one section. I would take the truck to a muffler shop and have them cut out that section. Using a DI/DO muffler of your choice (FlowMaster, Magnaflow, etc), I would run dual exhaust tubes from the cats to the muffler. Now, the lengths of the exhaust tubes to the muffler will not be equal but the DI/DO muffler will mimic an X-pipe/H-pipe to some degree. Then have two exhaust tubes run from the muffler to either the front of the rear passenger side wheel or out the back. You can use two mufflers (SI/SO) but it will cost more $$$. Depending on the other performance add-on's you have or plan to install (headers, high-flow cats, CAI kit, tuner, etc), you can either use 2.25" exhaust tubing for the stock setup or 2.5" exhaust tubing for the modified setup. 3" exhaust tubing is not recommended unless you plan to install a super charger.
Let us know what you decide to install and post pics!
Old Mar 13, 2009 | 03:23 PM
JakeShell's Avatar
JakeShell
thank you for the help...pics will deff. get posted!
Old Mar 13, 2009 | 06:32 PM
Furian's Avatar
Furian
You're welcome and I look forward to the pics... Have a great weekend!
Old Mar 13, 2009 | 08:20 PM
ford12508's Avatar
ford12508
not to hijack this, but why would 3" pipes not be recommended? I can see they would be a little overkill with out a supercharger as 2.5" would never really have that high of a back pressure without a S/C where they would need it, but wouldn't it be better to get the 3"s to have future compatibilities?
Old Mar 13, 2009 | 08:55 PM
patrickke's Avatar
patrickke
it would kill some power
drizzie27
Mar 21, 2012 10:30 PM
green53
Oct 30, 2010 11:27 AM
flyin 51
Feb 22, 2010 04:44 PM
jb10
19
Nov 24, 2009 08:13 AM
