E4OD chatters
Old Feb 18, 2009 | 07:18 PM
Bear 45/70's Avatar
Bear 45/70
E4OD chatters
The E4OD in my 1999 Ranger XLT 4.0 liter chatters when shifting into and out of OD under light throttle conditions. This started at just over 100K miles. The trans has been serviced regularly.
Old Feb 19, 2009 | 12:13 AM
mark a.'s Avatar
mark a.
100k is about all the longer the tc last in them.
Old Feb 19, 2009 | 02:37 AM
Bear 45/70's Avatar
Bear 45/70
Strange statement. The E4OD in my 1993 Crown Victoria Police Intercepter has 158K on it with a lot rougher service and it still works fine.
Old Feb 19, 2009 | 12:31 PM
jim henderson's Avatar
jim henderson
Sounds like classic torque shudder. During light acceleration in 3rd or 4th/OD you will feel a shudder or chatter. During hard accleration or coasting you won't feel this. Usually happened at 40-55mph on my F250.
Torque shudder is usually the torque converter lockup clutch going bad. It will start to slip which will overheat things(check fluid for color and smell) which will cause debris to flake off into the fluid which will eventually cause damage. A symptom of damage will be intermittant harsh shifting.
Sometimes a fluid change will fix it. Some people say some of the additives will work. In the long run you will need a new TC or a rebuild if you let it get too far along.
You might see if you can pull the tranny code, if there are any, and see what it says. Usually the computer will increase the pressure to try to force the clutch to hold. This may also account for harsh shifting.
Good Luck,
Jim Henderson
Old Feb 19, 2009 | 12:42 PM
Bear 45/70's Avatar
Bear 45/70
Changed the fluid with no change in the chatter. I thought it would fix the chatter, but no such luck. No tranny codes. The only code the truck ever throws regularly is the IAC. The speed sensor died once, but other than that the truck has been problem free.
Old Feb 19, 2009 | 01:31 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A '99 Ranger had a 5R55E, not an E4OD. A '93 Crown Vic PI had an AODE, not an E4OD.
Shudder can sometimes be fixed with a complete fluid change. Sometimes it takes a new torque converter.
Old Feb 19, 2009 | 01:37 PM
Bear 45/70's Avatar
Bear 45/70
I was told that E4OD covered all the 4 speed OD auto trannys and then they broke down by model from there.
RVEN
Oct 30, 2007 09:17 AM
MR. HALLETT
Oct 24, 2006 07:58 PM
fordtruckfan90
Mar 18, 2004 06:28 PM
AstewartPE
Feb 11, 2004 02:08 PM
