Injectors
Old Feb 19, 2009 | 10:15 AM
bradcollison's Avatar
bradcollison
Wait a minute.
You need to verify your fuel pressure. minimum is > 45PSI.
Have you done this?
If not, you need to before we can help.
If you have low fuel pressure it galls the plunger in the barrel of the injector and will burn it up. The fuel lubricates and cools the injector.
Old Feb 19, 2009 | 04:32 PM
preston77's Avatar
preston77
Originally Posted by tex25025
Fuel gelling yes that would need very cold weather, FICM not so much. 30s or 40s would get that little dodad. It might have been stressed bad in December and just now decided to crap out.
You have injector problems, so it's either going to be the control module, fuel(or related fuel issues: dead-heading, bad fuel etc), or the power programmer that you have on there or a combination of all those.
Do you get all your fuel at the same spot or do you switch it around? Does it have issues with having bad fuel or does it have a high turnover?
Does it only happen with the SCT on there or does it do it every time?
Now that you said that ya got me thinking. I always go to 1 place but recently I've been stopping at another here and there. I bet its the fuel from that place!!! The 1rst time was with the Edge, 2nd was with the Banks and now its the SCT. Everytime it's been with some sort of program.
Old Feb 19, 2009 | 04:34 PM
preston77's Avatar
preston77
Originally Posted by texans
just a thought what kind of oil do you run? How often do you change it? Maybe its an issue with the oil side of the injector.
I use the Shell Rotella T or whatever it is. I'm actually due for an oil change now that ya mention it.
Old Feb 19, 2009 | 06:14 PM
cowboybootlegger's Avatar
cowboybootlegger
How long do you go between oil changes? Most folks don't recommend much beyond 5k with conventional oil. (or syn for that matter)
Old Feb 19, 2009 | 06:24 PM
toolman05kr's Avatar
toolman05kr
Originally Posted by bradcollison
Wait a minute.
Have you done this?
Absolutley!!! Contribution error, Step 1 check fuel pressure. Fuel pumps and pressure regulator pintle seals going bad are not uncommon.
Old Feb 20, 2009 | 07:01 AM
preston77's Avatar
preston77
Wait a minute.
Have you done this?
I went through the SCT options on the monitor side and I don't see where I can monitor the fuel pressure. How can I check this? But I did do another engine check on it with the SCT and it gave me 10 different codes and I cleared them.
Old Feb 20, 2009 | 07:03 AM
preston77's Avatar
preston77
I dont ever go over 3500 miles and every other oil change I change both fuel filters.
Old Feb 20, 2009 | 07:19 PM
preston77's Avatar
preston77
Ok so I made a list of the dtc's it gave after I cleared them so maybe this will help.
0261, 0264, 0267, 0270, 0273, 0276, 0279, 0282, cylinder 1-8 low circuit
0266 cylinder 2 balance fault
can't find 0611 or 0000
Any suggestions lol?
nmlewis
Feb 20, 2015 07:06 AM
maxtruck00
Jun 5, 2014 07:25 AM
Greek 350
Apr 13, 2012 07:19 PM
06powerstroke06
Feb 25, 2009 12:47 PM
adambomb
May 16, 2007 07:56 PM
