Help Needed!........ UVCH?'s
Old Feb 15, 2009 | 09:54 AM
05chop's Avatar
05chop
What other codes do you have did you clear the codes that you created?
Old Feb 15, 2009 | 10:02 AM
05chop's Avatar
05chop
Looks like you have some spare part availably! Try swap out a know good PCM!
Old Feb 15, 2009 | 10:11 AM
Bergerson's Avatar
Bergerson
OMFG!!!
I found a chafed wire, was grounding out and shutting down the passenger side injectors.......
while the truck was in limp mode no power was going throu the wires, i had my daughter crank the truck over and while clearing the code! I found it!! shocked the living crap out of me!! cut out bad spot soldered back together and put some heat shrink on, then put a large piece of heat shrink around the whole harness where it rides on the vc, I am not quite sure why when i ohmed those wires from plug to plug it did not show up then but it didnt.... just goes to show.. check, double check, and then get the crap shocked out of you!!
Thank you everyone for the help and support!! you guys are the best around and I value all of your help!! hopefully I can help someone along the way one of these days!!
Bryan
Old Feb 15, 2009 | 10:30 AM
clintbonnie's Avatar
clintbonnie
Yes, that has been a problem in the past. I have read posts about the harness rubbing on the driver's side valve cover.. Everyone should check theirs. Glad you got her fixed...
Old Feb 15, 2009 | 02:37 PM
7.3johnsonville's Avatar
7.3johnsonville
Glad to hear you got it fixed. J/w how many miles you have when this was fixed?
Old Feb 15, 2009 | 04:47 PM
StanleyZ's Avatar
StanleyZ
what is a UVHC
OK guys, I gotta ask what a UVCH is. I figured out the VC was for valve cover, although when i first saw it I had flashbacks and started looking for my M60.
Old Feb 15, 2009 | 05:28 PM
Automator's Avatar
Automator
I believe it is Under Valve Cover Harness.
Old Feb 15, 2009 | 05:56 PM
StanleyZ's Avatar
StanleyZ
Got it, thanks. I've seen it just didn't know the acronym.
Old Feb 15, 2009 | 08:29 PM
Bergerson's Avatar
Bergerson
I've got just a tad over 230,000mi on her...
Old May 14, 2025 | 08:34 PM
Joshhaines's Avatar
Joshhaines
5th Gear
Originally Posted by Bergerson
OMFG!!!
Bryan
I think I’m having this same issue currently. I’ve swapped so many parts and connectors and still have my passenger side not firing. By chance do you remember what wire was chaffed? Sorry I know it’s 15 years later.
Old May 15, 2025 | 01:52 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Great walk down memory lane here.
Prolly a chaffed wire on the 42 pin harness that drapes over the driver side valve cover. See pic.
But best thing to do is start your own new thread with pics as needed.
Got a way to read the codes?
kt19
Oct 27, 2014 05:37 PM
Jesser02EX
15
Sep 13, 2013 01:51 PM
Studawg
77
Jun 28, 2012 01:23 PM
ghig1967
Apr 11, 2011 09:35 AM
Unrealo4
Jan 18, 2011 08:11 PM
