estimated hp/ torque
Old Feb 9, 2009 | 08:11 PM
crazer42's Avatar
crazer42
i was just wondering if you all would have a ball park for numbers.
my truck just has the SCT tuner, 4in turbo back exhaust, and an AFE cold air intake what would be my hp and torque numbers be??
Old Feb 9, 2009 | 08:32 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
300/600 if you're lucky, but pulling through 35's probably more like 280/550.
Old Feb 9, 2009 | 08:36 PM
stroken's Avatar
stroken
What he said, probably a little lower on tourque...look in my sig at mods, and only had 800 somthing Torque...
Old Feb 9, 2009 | 08:40 PM
cookie88's Avatar
cookie88
FTE Emeritus
Your numbers look about right to me. You are probably losing 30 and 50 though those 38" tires.
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
But you were also stretching a rubber band too.
You probably put 300hp and 575 tq to the wheels.
Old Feb 9, 2009 | 08:42 PM
stroken's Avatar
stroken
I cant wait to re-dyno with the BTS, Water meth, K31 and new tuning!
Old Feb 9, 2009 | 08:46 PM
PowerstrokeJunkie
499.9hp wouldnt that be your luck
Old Feb 9, 2009 | 08:49 PM
stroken's Avatar
stroken
probably. When I see anything higher then 500hp and 1000 foot pounds of tourque I will be happy! Your right, will just be my like the see 499.9 and 999.9!
Old Feb 9, 2009 | 08:56 PM
CSIPSD's Avatar
CSIPSD
Really supprized with your low TQ numbers... I have been in the 400-1000 range every time I have dynoed...
467-1050 last time... With the TN BB...
To the OP... About 280-300hp, 550-600 TQ
Old Feb 9, 2009 | 08:59 PM
stroken's Avatar
stroken
hmm, now I am too, lol
Well as I posted before with the 410 I only had a stock h2e, my trans wouldnt hold OD kept going between the two gears, boost leak, huge tires, no meth and a POS 6.0 IC
Old Feb 9, 2009 | 09:03 PM
CSIPSD's Avatar
CSIPSD
Stock gears in the axles??? That K31 is a pig to spool with that much rubber to turn I am sure...
Old Feb 9, 2009 | 09:18 PM
stroken's Avatar
stroken
stock gears for now, 4.56 and detroit locker comming soon!
Old Feb 9, 2009 | 09:28 PM
PowerstrokeJunkie
not with his rubbery slippin-*** converter, it spools awesome, it would be hard to spool if the trans actually locked in like a manual transmission
Old Feb 10, 2009 | 11:27 AM
crazer42's Avatar
crazer42
so when does the stock transmition no longer cut it. what power level will tear it up
Old Feb 10, 2009 | 11:30 AM
stroken's Avatar
stroken
mine took a **** at 82 thousand miles, with no chip. bone stock.
kedwinh
Jan 19, 2012 09:22 PM
mcons1
Feb 25, 2011 01:32 PM
farmb0y
Mar 6, 2010 02:36 PM
crazer42
15
Nov 14, 2007 09:11 PM
rustyolred27
Oct 30, 2004 07:36 PM
