stock numbers
Old Nov 12, 2007 | 05:25 PM
crazer42's Avatar
crazer42
stock numbers
does anyone know the stock ratings on the 7.3( hp and torque) just wanted to know how muchmore power the stock 6.4 has and if i would notice a big difference while towing
Old Nov 12, 2007 | 05:26 PM
powerstroked162's Avatar
powerstroked162
245/520 isn't it.......?
Having owned both a 6.4 and a 7.3 I will say that the 7.3 hands down gets better fuel mileage and has more low end grunt. The 6.4 is a towing machine though so I would say it comes down to the fact of how often and how much do you tow. If you are a monthly tower then I would say get you a nice, clean , used 7.3 and have fun because you'll get twice the fuel mileage outta the 7.3 then you will with the 6.4, but if your a weekly tower and need the big towing capacities then hop on the band wagon and get ya a 6.4
Cowboy Steve
Old Nov 12, 2007 | 05:31 PM
F250_'s Avatar
F250_
Some years, the 7.3 was 225 HP (like my 2002), others were 250 HP. Not sure about torque numbers.
Old Nov 12, 2007 | 05:46 PM
Pocket's Avatar
Pocket
250hp rating was for the 6-speed manual trannies.
Old Nov 12, 2007 | 06:33 PM
mudmaker's Avatar
mudmaker
I thought the 225 was pre 99.
I dont know the hp, but mine has a sticker on the rear window that says 525 tq
Old Nov 13, 2007 | 02:51 AM
ernesteugene's Avatar
ernesteugene
Check this thread...
https://www.ford-trucks.com/forums/666835-a-quick-way-to-estimate-your-dyno-results.html#post5265024
for RWHP and RWTQ curves for a stock 99.5 with an auto tranny, as measured on a water brake load dyno.
Max RWHP=212.2 HP at 2600 RPM, and Max RWTQ=463.1 lb-ft at 1800 RPM.
Old Nov 13, 2007 | 04:28 AM
Izzy351's Avatar
Izzy351
I thought for '02 it was 250/515 for auto and 275/520 for standard or something real close to that (at the flywheel)...
EDIT: Found this on the specs page here on FTE for the '02 F250 with the 7.3:
"The 7.3L Power Stroke<SUP>TM</SUP> turbo diesel V-8, the best-selling engine in its class - gas or diesel, produces 250 horsepower and 505 lb.-ft. of torque with the automatic transmission; or 275 horsepower and 520 lb.-ft. of torque when joined to the manual transmission."
See it here:
https://www.ford-trucks.com/specs/20...series_SD.html
Old Nov 13, 2007 | 08:04 AM
F250_'s Avatar
F250_
Thanks, Joe... I could have sworn I saw 225 on my stickers in the truck... my mistake.
Old Nov 13, 2007 | 11:58 AM
powerstroked162
225hp was the rated output of the OBS 7.3's
Cowboy Steve
Old Nov 13, 2007 | 02:40 PM
ernesteugene
See it here:
https://www.ford-trucks.com/specs/2002/2002_f-series_SD.html
So if you use your 250 flywheel HP and a 15.1% driveline loss, you get the RWHP=212.2 number that I gave! In addition, I gave measured curves vs RPM for both RWHP and RWTQ, and I believe those are dead on accurate as measured on a load (not inertial) dyno.
I've used those curves to help calibrate the volumetric and thermodynamic efficiency functions in my PSD engine model, so that my model now produces curves that match the measured ones very closely.
Old Nov 13, 2007 | 04:06 PM
powerstroked162
Cowboy Steve
Old Nov 13, 2007 | 05:25 PM
tholt34's Avatar
tholt34
My 2000 model with a auto says 235 hp @ 2600 rpm on the passenger side valve cover sticker.
Old Nov 13, 2007 | 06:39 PM
powerstrokinsmokin's Avatar
powerstrokinsmokin
ernesteugene, I would have to agree about the water braek dyno, that it true hp at the wheels while drawing down the engine. Also it measures an accurate hp through load, not speed of how fast/quick you can spin the rear tires. Although I will say both dyno numbers will be close. Just remember everyone that you will never get identical dyno numbers, even in the same truck back to back. Trust me, I dyno trucks at work (Mack & Volvo) dealership and a lot of other trucks. Gearing, suspension and a lot of other factors play into getting those numbers.
Old Nov 13, 2007 | 09:35 PM
santacruzf250's Avatar
santacruzf250
Haha. All these numbers are different from the FTE website.
Go up top to Articles/Specs ====> Click down to Specs... Select your year and then click specs again.
2000 => 235hp, 500ft/Tq. (Man and Auto)
2001 => The 7.3L Power Stroke® turbo diesel V-8 produces 250 horsepower (15 more than last year) and 505 lb.-ft. of torque with the automatic transmission, and 275 horsepower and 420 lb.-ft. of torque when joined to a manual transmission (late availability)
2002 => 275hp, 520 ft/tq. MANUAL
2002 => 250hp, 505ft/tq. AUTO
2003 => 7.3L same as 2002
There we go, straight from the FTE website...
I'm curious to know why there is a 100ft/tq. jump between 2001 and 2002. Use of new tranny or something? Possibly a typo?
Old Nov 14, 2007 | 08:11 PM
mudmaker's Avatar
mudmaker
I think the typo is the auto torque in 02. I have a sticker on my window that says psd 525 ft lbs torque.
