Anyone own a ThunderBird SC?
Les
that thing will slide if the dog goes on the tires.
John
alanscott
[link:ford-trucks.com/users/alanscott/|http://www.ford-trucks.net/users/alanscott/clubftesml.jpg]...Click!
They are very nice cars and run beautifully.. If you do end up getting it good luck with it and have fun driving it. Their steering is incredible... Good LuckEvery winter i put snow tires on back and weight in the trunk and it seems to do pretty good. it's only a V6 so there isn't too much of a problem with being overpowered.
With an SC you really need to be careful when it rains, especially when pulling out of parking lots. The SC has a lot of torque and it you get on the throttle thinking you can make it out into that small space in traffic it is really easy for the back tires to break loose when it's wet.
I have really enjoyed my SC, but I don't think it's an "all weather car"..........Just my 2 cents worth.
Jared
Is this car a five-speed? If it is and is in good shape, I would keep it away from road salt. Definitely a future collectable, more so than their turbo four predecessors.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds
.Check out my Gallery for a look-see.
Justin - One Happy FTE Member
>stuck on 4 studded Goodyear winter tires....really knobby
>ones, and 2 sandbags in the trunk. The thing was great in
>the snow. It really surprised me as I wasn't expecting much.
>A lot of times she made it around in the snow when I figured
>she would be calling for a ride in my 4X4. The combination
>of lots of torque (allowing you to idle off from a start),
>limited slip, knobby tires and ABS really works well. The
>ABS on these works a lot better than a lot of ABS systems.
>She got used to looking in her mirror before coming up to a
>stop sign to make sure no one was close behind....she could
>stop fast and they might not be able to.
You are actually better off having tires with small ***** and cuts/sipes for winter traction. Snow tires are a softer compound and are "sticky" on ice. Ice itself is not slippery, it's water ontop of the ice that makes it slippery and snow tires tent to "absorb" water and are more grippy on ice. That is a major difference in snow tires vs all season tires. Big knobby tires used to be used years ago, because they do a good job in deep snow. But they do very poorly in ice/packed snow which is probably the most important on a car. If you look at any new snow tires, they all have very small treads and many many cuts/sipes in them.
