Engine stumbles when wipers wipe window
Old Feb 17, 2009 | 01:31 PM
dougwood62's Avatar
dougwood62
I went and drove my truck today to see if it is still has the CPS problem. It seems to be fixed. I drove for about 20mi and tried my wipers at all speeds and it didn't do it once. The other day it did it almost instantly. I hope that is all it was. thanks for all your help.
Old Feb 17, 2009 | 11:46 PM
7.3johnsonville's Avatar
7.3johnsonville
i swapped to grey CPS and no more wiper problems. still have black cps for backup tho..
Old Feb 18, 2009 | 06:03 AM
OTTOMATIC's Avatar
OTTOMATIC
I have the gray CPS and it still does it. No leaks.
Old Feb 18, 2009 | 06:18 AM
4EXTRDR's Avatar
4EXTRDR
A couple things come to mind here...
First, the AC compressor is on in every position except vent only (one click to the left of off), off, and floor heat only. In every other switch position, the compressor runs.
That is Very Interesting! I always thought something was wrong w/ my truck because the A/C compressor would cycle on normal Heat settings and I tow everyday and didn't want the power loss. Im gonna try the other selections on the **** to keep the compressor off...Cool! This was driving me nuts for a long time
Old Feb 18, 2009 | 08:22 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by HKusp
Have any of you had your windshield replaced? My wife's Expedition had a windshield replacement and there was a tiny leak down the passenger compartment side of the fire wall. It would get wet when it rained and all kinds of weird things would happen.
This is the first thought that came to my mind when reading the original post.
Originally Posted by dougwood62
I have the same problem with my truck. It only stumbles when it rains. I never connected it with the windshield wipers though. I also have noticed after I drive my truck I get water on the ground by the passenger door like HKusp said. This never happened before. I haven't noticed any water getting inside the truck I will check that today. I am glad I am not the only one having this problem. Now lets put our heads together and figure this out.
You really want to get this fixed.
Here in Seattle with it's wet marine climate what happens is the condensation builds up on the INSIDE OF THE printed circuits and turns the whole circuit board corroded like a bad battery post. The outside of the box looks ok, but if you take the cover off, it is all green and moldy looking, like it's been bathed in salt water.
In this climate the tell-tale sign is dew on the inside of the window in the morning.
If I see that on any of my cars I start dealing with it right away because it will head off a lot of very much more expensive repairs later on.
Old Feb 18, 2009 | 10:45 AM
dougwood62's Avatar
dougwood62
Question
I am not getting water inside at all. just on the outside. where do I check for corrosion? I want to check anyway just in case. But ever since I had the sensor changed, it stopped having the problem. But now I am hearing about how the recall sensor cause trucks to run rough. I hope that doesn't happen to me.
Old Feb 18, 2009 | 11:31 AM
afonda's Avatar
afonda
This is the craziest thing I have heard of!!!!!!!!!
Better hope it doesn't rain.
Yet yourself some rain-X.
Old Feb 18, 2009 | 01:16 PM
gmm's Avatar
gmm
About the truck dying when you hit the fender, the IDM is in the drivers fender, it may have a loose connector.
Jaden McDonnell
Jul 13, 2017 06:55 AM
Jaden McDonnell
Jul 11, 2017 01:14 PM
chrissknr
28
Apr 26, 2013 02:30 PM
willeo6709
Jun 18, 2010 08:01 PM
karnett
Jun 15, 2006 03:03 PM
