Windshield Wipers Concern
Old Jul 11, 2017 | 02:34 PM
Jaden McDonnell's Avatar
Jaden McDonnell
Question Windshield Wipers Concern
A few weeks ago I replaced my CPS on the 99 7.3. Today was the first day I drove my truck in the rain. When I turned my wipers on, I noticed that I lost power and my truck started hiccuping. I read on these forums that an aftermarket CPS is most likely the problem, so I am planning on getting a ford CPS this afternoon. My biggest concern is that before I replaced my CPS, my wipers only had 2 speeds. Also, if I pressed the end of the blinker switch to squirt the cleaner the wipers would not turn off until I turned the truck off. I am not sure why this would be happening and I wanted to ask if there is more than just the CPS involved with this.
Thank you
Old Jul 11, 2017 | 04:42 PM
Njstern87's Avatar
Njstern87
Could be the wiper switch going out or the contacts being worn to cause the wipers strange behavior. Non oem cps and hiccups are pretty common though.
Old Jul 11, 2017 | 08:50 PM
Jaden McDonnell
I changed the wiper switch that's why I don't know what to do next and I don't want to buy a new motor if that's not the problem. Any other ideas? Thanks
Old Jul 12, 2017 | 02:06 PM
AllaboutMPG's Avatar
AllaboutMPG
First thing to do is get an OEM CPS in it. Check your grounds, especially the one on the driver side of the engine bay. Clean and reinstall.
Some reading for you
https://www.ford-trucks.com/forums/9...werstroke.html
Old Jul 12, 2017 | 03:07 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Like stated above, a non-OEM CPS will have identical issues with wipers as you describe.
Old Jul 12, 2017 | 08:11 PM
Jaden McDonnell
I replaced the CPS and that solved my first problem with the truck dying. Now the wipers are Just how they used to be, only 2 settings work and the wipers are intermittent at times. I checked my ground and cleaned it off when I replaced my hydroboost cooler lines last week. Any other ideas? Thanks
Old Jul 12, 2017 | 10:38 PM
mecdac's Avatar
mecdac
Any odd noise(s) while the wipers are operating?
About 5 months ago I noticed a slight grinding noise. Had the stereo been on I would not have noticed. Under the cowl the linkage was wearing out repaired, then a few weeks back the "High/Fast" speed was intermittent, since you have already replaced your multi-switch, it's most likely the wiper motor itself. Sorry.
Old Jul 13, 2017 | 06:55 AM
Whitey Ford
I replaced the CPS
What brand CPS did you go with?
Jaden McDonnell
Jul 11, 2017 01:14 PM
Arney
13
Oct 10, 2015 01:25 PM
Elwskw
Oct 4, 2012 11:44 AM
Redully
Apr 11, 2012 10:49 PM
BriansPence
Feb 14, 2010 08:53 PM
