vin info.
Old Feb 2, 2009 | 05:11 PM
Faber's Avatar
Faber
vin info.
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message -->
<!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --><!-- END TEMPLATE: ad_showthread_firstpost_start -->I know you guys are good, and get tired of hearing these....so I appoligize, but wondered if anyone could give me any info.;
Seriel number; F10JK553996 (if this will tell anyone anything)
and;
114-B-F100-381-A-12
Thanks guys....
Old Feb 2, 2009 | 05:31 PM
camperspecial65's Avatar
camperspecial65
F= F series conventional cab truck
10 = 1/2 ton 2WD
J = 223 6 cylinder engine, 114HP
K = Kansas City assembly plant
553996 = June 1964 build date, 1964 model truck
114 = wheelbase in inches
B = Turqoise exterior paint
F100 = model of truck
3 = base model truck with medium green crush vinyl and medium green rib vinyl
81= 81A= base model truck...a number in front of the 81 denotes a base model truck, a letter would denote a Custom Cab trimmed truck
A = 3 speed trans.
12 = DSO..where original selling dealer ordered truck from...Buffalo, N.Y.
- cs65
Old Feb 2, 2009 | 05:52 PM
Faber's Avatar
Faber
Thank you sir!....sorry bout' the double post, figured should have titled it different....Thanks again!
Anyone know how to find out rear end type?
Old Feb 2, 2009 | 07:15 PM
masterqi's Avatar
masterqi
Actually I believe the "12" referenced at the end of that plate sequence would indicate a Ford 9 inch 3.89 rear end.
Old Feb 2, 2009 | 07:23 PM
Faber's Avatar
Faber
Hey, I appreciate that!....Thanks guys....
Old Feb 2, 2009 | 08:35 PM
Faber's Avatar
Faber
Thanks again guys....
Old Feb 4, 2009 | 12:49 AM
camperspecial65
You would be correct on the rear end ratio code...12 though is for a 3.89 ratio....if you look under the truck and see a bunch of nuts around the pumpkin on the forward side of rear axle husing, that is a Ford 9" rear end...if not its a Dana 44 if Im not mistaken...
BTW...there oughta be some other numbers after the 12 where it says DSO...if blank thats odd as I am pretty certain 64 models did show the DSO code on the door tags...
- cs65
Old Feb 4, 2009 | 07:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
BTW...there oughta be some other numbers after the 12 where it says DSO...if blank thats odd as I am pretty certain 64 models did show the DSO code on the door tags...- cs65
The same Warranty Plate was used in 1965.
Besides the DSO, the OP also omitted the GVWR, HP & RPM.
If Limited Slip was ordered, the Spicer-Dana 44 was installed.
The Spicer-Dana 60 with or without Limited Slip was an option.
AXLE code 12 = Used 1961/64 only for this: Ford 9 inch / 3.89-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
12 was not used in 1965.
12 = 1966: Ford 9 inch / 4.11-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
Old Feb 4, 2009 | 11:25 AM
Faber's Avatar
Faber
man you guys are good....
o.k. here's what i got, hopefully i'll get it all this time....
on the door tag;
F10JK553996
114 B F100 381 A 12
5000 114 3600 53
I saw DSO, but this is all the info. on the tag.
Didn't see any tag in glove box or inside glovebox door, except a paper sticker with recomended oils.
On the front of the rear end bout' 4 o'clock or so on tin plate;
WBC-F2
3.89 4FA 301
Stamped in the front on the rear end, each line by itself;
-D
-DIF26
-4E28
Whata' ya' think?
Old Feb 6, 2009 | 08:39 AM
Faber's Avatar
Faber
bump..............
CraigerF100
Dec 9, 2012 06:26 AM
senix
Feb 12, 2010 01:42 PM
mikersix
Jan 14, 2010 11:25 PM
el cheapo
1983 - 2012 Ranger & B-Series
Oct 7, 2009 10:58 PM
428HIGHBOY
15
Feb 17, 2009 07:02 PM
