brake caliper problem
Old Jan 13, 2010 | 06:25 PM
mikersix's Avatar
mikersix
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message -->
<!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --><!-- END TEMPLATE: ad_showthread_firstpost_start -->I replaced the rotor and pads on my 2000 expedition but now i am having a problem replacing the 2 t45 bolt through the caliper into the caliper bracket. i can get the top one in ok but the holes on the bottom are not lining up. the caliper is riding about 1/8 of an inch too high to line up. anyone run into this problem?
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old Jan 13, 2010 | 08:07 PM
fordtech08's Avatar
fordtech08
is the slide out and when you try to line up the caliper it's hitting?
Old Jan 13, 2010 | 08:31 PM
alloro's Avatar
alloro
Originally Posted by mikersix
I can get the top one in ok but the holes on the bottom are not lining up. the caliper is riding about 1/8 of an inch too high to line up. anyone run into this problem?
You didn't mix up parts from different wheels did you? Didn't think so!
Loosen the top bolt so that it's in by only a few threads, then thread the bottom one in.
Old Jan 13, 2010 | 10:09 PM
Gevans17's Avatar
Gevans17
Brake caliper not lining up
Dont worry..brake calipers are idiot proof..they only go in 1 way, so keep playing with it!
Old Jan 14, 2010 | 07:45 AM
fordtech08's Avatar
fordtech08
also make sure you didn't twist your your brake hose, if it looks like a pigs tail you got it wrong, calipers are not idiot proof a few people have come into my shop with a caliper they just bought on the wrong side, but alloro was meaning was the brackets
Old Jan 14, 2010 | 08:21 AM
mikersix's Avatar
mikersix
I didn't mix up sides doing one at a time. But the brakes were REALLY bad. The inside plate on the rotor was completely gone. only the ribs were left. Probably going to change the caliper and bracket because of it being so bad. It just ticks me off though, that I can't get back on what i took off. Maybe bracket or cailper warped due to heat and I released the pressure when removing? Anyway, Thank for help.
Old Jan 14, 2010 | 08:23 AM
fordtech08's Avatar
fordtech08
don't give up yet, can you put the caliper onto the bracket off the truck?
Old Jan 14, 2010 | 05:26 PM
mikersix's Avatar
mikersix
Ok I got it!. It came to me in a dream!!! I used a C-clamp the try to move the caliper down. I tightened it just a little and the thing popped into place. Matter of fact I had to pull it up a little but it went right in. Passenger side a dream compared to this side. This is the second bad brake job I did in a row and they happen to be my first two. I read alot of forums about trying to remove stuck rotors but I found a way that is SSOOO easy! I bought a gear puller with 7" inch arms and the rotors come off like butter. No more hammering or cutting. I do have one question though. I noticed that my drivers side bracket and caliper looked just like my passenger side only upside down. Is this right or did the previous owner or whoever worked on this truck screw it up?
Old Jan 14, 2010 | 05:30 PM
fordtech08's Avatar
fordtech08
as long as the bleeder screws are at the top of the caliper your fine
Old Jan 14, 2010 | 11:25 PM
Gevans17's Avatar
Gevans17
calipers
Well, I didn't mean a COMPLETE idiot!
Hotairjunkie
Jul 10, 2009 11:15 AM
68futura
34
May 12, 2009 09:58 PM
1eyedjack
65
Apr 24, 2009 02:58 PM
428HIGHBOY
15
Feb 17, 2009 07:02 PM
