DIY auxillary lights!!!
Old Feb 2, 2009 | 11:09 AM
jay-rod427's Avatar
jay-rod427
DIY auxillary lights!!! W/Pics
1.5" angle iron with holes drilled for mounting lights and mounting to core support.
http://i690.photobucket.com/albums/v...1233593655.jpg
Core support existing hole, then I drilled a new hole right beside it(not shown).
http://i690.photobucket.com/albums/v...1233593658.jpg
Lights mounted to the bracket and bolted in place.
http://i690.photobucket.com/albums/v...1233593661.jpg
Lights shining through Roush Grille.
http://i690.photobucket.com/albums/v...1233593672.jpg
Lights turned off with hood closed.
http://i690.photobucket.com/albums/v...1233593968.jpg
Headlight pattern on the wall compared to brights.
http://i690.photobucket.com/albums/v...1233593669.jpg
T-tap into the headlight brights wire(green/black stripe).
http://i690.photobucket.com/albums/v...1233593665.jpg
I didn't want to put a switch anywhere so i just tapped into the wire for the high beams with a T-tap, and used it for the trigger on a 40 amp relay.
Roush Grille= $99.00 on Roush overstock. (super easy 20 minute install)
KC 100W Hilites= $109.00 from Autozone.
Various wiring connections, and flex conduit, to resupply the garage $50.00
Old Feb 2, 2009 | 03:31 PM
98greensi's Avatar
98greensi
looks great, that has to be the most simplest but strong bracket i've seen made so far. how is the light output shining threw the roush grill at night?
great write up but if you click on this icon then insert you link of the picture like you did the pictures will show up on this thread..
Old Feb 2, 2009 | 03:47 PM
jay-rod427's Avatar
jay-rod427
When I was adjusting them at night and shut the hood i did notice a little difference in light output, but they are still really bright.
I will have to mess with the photo uploads a little more, I couldn't get it to work that way at first. Thanks for the advice.
Old Feb 2, 2009 | 04:54 PM
Saleenguy's Avatar
Saleenguy
That looks great.
I actually plan to do something similar to that on my 2009 F350 when it arrives.
Old Feb 2, 2009 | 06:52 PM
shorebird's Avatar
shorebird
Let me try;
Old Feb 3, 2009 | 03:38 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
looks pretty cool.
wish my "H" bar grille didn't block so much. otherwise I'd do something similar.
Old Feb 3, 2009 | 08:59 AM
jay-rod427's Avatar
jay-rod427
Tylus, you could get somebody's black powdercoated billet grill and do the same thing, i know you want to keep all the black/white goin, it looks good on your truck. i know what you mean about the "H" bar grille I didn't have my truck a month brand new and it had to go.
To anyone else I highly recommend the Roush Grille, yeah it is just chrome over plastic, but for $100 and super clean and easy install you can't beat it.
Old Feb 3, 2009 | 09:05 AM
jay-rod427's Avatar
jay-rod427
Tylus,
Hella lights also makes a pretty sweet setup that would look pretty mean on your truck, the reflector turns black when the light is off. That would completely disappear behind a black grill... they are pretty expensive though.
My Hella Lights - Black Magic Series lamps
njneer1
1978 - 1996 Big Bronco
Jun 28, 2011 07:58 PM
jay-rod427
2004 - 2008 F150
15
Oct 20, 2009 10:40 AM
zenmaster
May 2, 2009 09:47 PM
zenmaster
Apr 23, 2009 08:24 PM
