Sponsored by: Real Truck
AOD tranny won't shift when cold
Old Feb 1, 2009 | 06:36 PM
IHF250fireman's Avatar
IHF250fireman
I have a tranny out of an 89 f250 4x4 that i put into a 78 f250 4x4, tranny shifted fine for about two weeks and now it won't shift out of first gear for about a mile. After that it shift and drives fine until it kools entirely back down. I changed fluid and filter didn't help. any suggestion.
Old Feb 1, 2009 | 11:51 PM
aldridgec's Avatar
aldridgec
You said AOD, but out of a 250 I would wager it was a C6. Do you know for sure?
Old Feb 2, 2009 | 10:22 PM
IHF250fireman
Yeah, i have done my homework and given the pan description and the bolt pattern. It is an AOD.
Old Feb 2, 2009 | 11:01 PM
aldridgec's Avatar
aldridgec
An AOD has a lot of valves. I've only been in a couple. Or one twice. Not sure... but I would suspect a valve is binding in the VB, and the expansion when it gets warm allows it to move. Anything happen when this occured. How is the fluid? Maybe you could drop the VB and see if any of the valves stick when it is cold. Also, throttle valve adjustment might cause this problem too.
Old Feb 3, 2009 | 08:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could also be a sticking governor. In fact, I'd even wager close to a dollar that it's the governor sticking.
You can get to the governor by removing the extension housing, but in a 4x4 that involves removing the transfer case.
Old Feb 4, 2009 | 10:31 AM
DavidB's Avatar
DavidB
I agree, Likely the governor
I agree with Mark, and I have rebuilt a lot of AODs.
manram
13
Feb 5, 2015 03:35 PM
83f-250
Feb 4, 2015 09:35 AM
mmunhollon21
Sep 14, 2014 09:58 AM
78fordfan
Aug 2, 2014 05:11 PM
basecamp
Mar 22, 2005 10:35 AM
