Shifting Problems
Old Feb 3, 2015 | 07:33 PM
83f-250's Avatar
83f-250
Shifting Problems
I'm going to ask for some opinions, my buddy has a 96 f150 with a 351 Windsor. It was fuel injected, with an automatic tranny. He pulled the fuel injected motor and put in a 351 with a 4 barrel holley. They used the wiring harness off the injected motor and just cut the injector wires off that way they could use the same computer. The truck runs great buy doesn't shift properly. When you take off it shifts at about 10 mph then again around 20mph. It won't down shift if you stand on it. The motor just sucks more gas and doesn't get up and go until you get back up to higher rpms. The tranny shifted fine with the other motor. What's the problem and a way to fix it?
Old Feb 3, 2015 | 09:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The computer isn't getting all the info it needs from the engine. I don't know how to make this mess work. I think the best way to do it is to get an aftermarket control system. PCS makes one.
Old Feb 3, 2015 | 10:01 PM
Conanski's Avatar
Conanski
Unfriggenbelievable!!
The computer in this vehicle controls both the engine and the trans and it needs input from both of those things to do the job correctly. So your options are...
A. Put the EFI motor back in and reconnect all the wiring.
B. Add all the EFI sensors to the carb setup and reconnect all the wiring.
C. Remove the trans and install a non computer controlled trans.
Old Feb 4, 2015 | 02:47 AM
83f-250's Avatar
83f-250
Well he did put a lot of the sensors back on but there are a few that he did not. We were also doing some research and a throttle position sensor(TPS) is offered by holley. It says that this is supposed to make a carbuerated motor work and shift properly with an electronically controlled tranny.
Old Feb 4, 2015 | 09:29 AM
RIKIL's Avatar
RIKIL
I spent too much time reading this thread...mostly because it is funny what the original owner did to the truck. He killed it.
Old Feb 4, 2015 | 09:35 AM
Conanski's Avatar
Conanski
Yes the TPS is one of those must have sensors.
MAN_N_BLACK
Nov 8, 2014 02:57 PM
Samsn4
Oct 27, 2013 01:11 PM
luckyguy1316
Oct 12, 2011 08:49 AM
peckhamjusten
Aug 30, 2006 08:47 AM
78bigbronco
Electrical Systems/Wiring
Aug 16, 2003 11:40 PM
