tranny wont shift to manual 1 - Ford Truck Enthusiasts Forums
Old 09-12-2014, 09:40 PM
mmunhollon21
mmunhollon21 is offline
mmunhollon21 is starting off with a positive reputation.
Question tranny wont shift to manual 1
I have a 2000 f350 4x4 single wheel one ton automatic transmission went out about 2 years ago and it was rebuilt. Recently if in drive it will shift perfect but just can't manually shift to first. I have taken the cable off the transmission and tryed to shift the lever by hand and it will not go to first. Any ideas?
Old 09-12-2014, 10:37 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is online now
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Does the shifter itself feel sloppy? Does it feel like it hits "park" correctly? There's two torx head bolts on the steering column under the dash that works loose and it could cause what you're describing...oops I read over the took the cable loose and it still wouldn't go..sorry.
Old 09-13-2014, 08:10 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Originally Posted by mmunhollon21 View Post
Any ideas?
Something is blocking the linkage or the manual valve from moving. Try removing the range sensor (that's the part with the wiring harness attached next to the shift lever that won't go to 1.) If it still won't move with that removed, then take the pan off and see what's wrong.
Old 09-13-2014, 08:33 PM
mmunhollon21
Thanks Mark I took the range sensor off and ended up being a small rock wedged between it and the transmission.
Old 09-13-2014, 10:59 PM
brushfit's Avatar
brushfit
brushfit is offline
brushfit is starting off with a positive reputation.
You got lucky!!! And Thanks to Mark and FTE!!!
Old 09-14-2014, 09:58 AM
retiredsparky
retiredsparky is offline
retiredsparky has a great reputation on FTE.retiredsparky has a great reputation on FTE.retiredsparky has a great reputation on FTE.retiredsparky has a great reputation on FTE.
Just when you think that Mark cannot possibly teach us anything more, there he goes! Fortunately he spoon feeds us or we would not remember any of it.
Larry
MRStace84
1978 - 1996 Big Bronco
07-18-2016 10:27 PM
MRStace84
07-18-2016 09:09 PM
African Fury
1999 to 2016 Super Duty
34
05-16-2016 11:07 PM
idihillbilly
07-04-2015 06:00 PM
6CylBill
10-18-2009 12:35 PM
Quick Reply: tranny wont shift to manual 1
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
