Starter envy!!!
Old Feb 28, 2009 | 09:25 PM
  #61
beanhead6D5's Avatar
beanhead6D5
Pete,that starter looks like it would flip over the truck when you crank it.LOL.
Looks good,I'll have to get one if mine ever goes out.
Old Feb 28, 2009 | 10:16 PM
  #62
USAF CCM's Avatar
USAF CCM
Originally Posted by lhud
Mine is also a 2002, F-250, 4x4, but my DB HT unit slid right in with no grinding required.
For Les in an earlier post, I tried finding a unit built in the good ole USA, but could not find a comparable unit to the DB. Due to the emergency at the time I purchased a new starter from NAPA and it left me stranded in a mall a short time later on a Sat. evening. Got that one replaced from NAPA the next day and on Monday ordered my DB unit - it arrived three days later (standard shipping).
Lots of miles later and the DB unit is still spinning the engine over as if it was new.
Comment on hard starting: Do not overlook the alternator when troubleshooting hard starting. It may produce enough to slowly turn the engine and eventually crank, but may not produce enough volts/amps to maintain proper volts, etc. on the sensors. A buddy of mine ('99 F250) was in the shop for nine days and it turned out to be the alternator. Now it runs like a champ.
Thanks guys,
Ihud,
Alas, I do understand. I wonder sometimes what has happened to the quality of some of the products we produce. I'm by no means a protectionist, but everytime I go into a hardware store, it seems every tool or part is made in China. I almost wish Nixon had never gone there.
Old Feb 28, 2009 | 11:41 PM
  #63
LoneRanger416's Avatar
LoneRanger416
Hey do you guys remember seeing a lable on your starters with a model # or howbout on your invoices? Im just trying to confirm at this point to make sure I got the right HT starter...
I will probably turn out as usual....Im a retarded mechanic
Old Feb 28, 2009 | 11:50 PM
  #64
spdmpo's Avatar
spdmpo
My invoice says Item # SND0355/17802 Ford 7.3 Diesel Starter Powerstroke Truck High Torque 2001-06
Same as what you posted on the other thread. I don't know what you could possibly be doing wrong, but you got the correct part #. Assuming the correct part is in the box, it is kind of a no brainer to put the new one in; unless you need to notch the cross member for clearance.
Old Mar 1, 2009 | 10:31 AM
  #65
LoneRanger416
Looks like I am going to have to grind the crossmember. Looks like 1/4 to 1/2 inch though. Gota nother prob. the solenoid wire connector broke in half. looks like it was corroding. Now gotta figure out how to slpice it.
Old Mar 1, 2009 | 11:45 AM
  #66
vettdvr's Avatar
vettdvr
Are the ones being notched 2wd or 4wd? there might be a clearance difference between the two.
Old Mar 1, 2009 | 11:53 AM
  #67
spdmpo's Avatar
spdmpo
Well mine is a 4wd CC LB and it didn't *need* to be notched. But I ground a little out anyway because it was so close (probably on .070 or .080), didn't want it hitting when things started moving around.
Old Mar 1, 2009 | 11:59 AM
  #68
F250_'s Avatar
F250_
From what I've seen in other posts, the grinding seems to be more typically required on 4WD trucks, but it also seems like the earlier eyars of the 2wd trucks may also need it. On the 2WD trucks, it might be an issue of which factory they were built in, but that's a purely speculative comment.
I did not need to do any grinding at all on my truck (2002 2WD, CC, SRW, SB, Kentucky Built).
Old Mar 1, 2009 | 12:07 PM
  #69
LoneRanger416
Yeah, mines a 02 4X4. Looks like I will have to notch the lip off in that area to get it in. Thinking back, I had an accident in the front end back in 06. The truck went back to the dealer and was put on a frame machine. All was straight. When Im under the truck everything looks in place. Stupid question but, I wonder if things moved back just a bit??
Old Mar 1, 2009 | 12:09 PM
  #70
F250_'s Avatar
F250_
Doubt the movement issue. The cross member is welded into place.
wtroger
Oct 23, 2013 12:55 PM
dfsmitty60
Oct 13, 2013 03:48 PM
c in southern oregon
Jul 2, 2011 11:59 PM
Durockrolly
Aug 15, 2010 02:42 PM
coplin
Feb 26, 2007 01:24 PM
