Starter envy!!!
Old Feb 3, 2009 | 11:25 AM
  #31
jkidd_39's Avatar
jkidd_39
Originally Posted by USAF CCM
After hearing about DB's alternator & starter on FTE some time ago I decided to upgrade my alternator & starter with DB's high output setup.
When I called DB to order, I had to ask the question "Are they made in China?" When he said yes, I became very sad and said thank you anyway. I just couldn't put Made in China stuff on my truck. Many reasons why but.....!
I try as much as possible to buy American, sometimes you just can't avoid overseas products, and sometimes there's good reason to buy a foreign product.
I'm just passing on my personal thoughts and in NO WAY pass on judgement on your decision. Best of success with you new starter. V/r Les
I used to be this way too.. But then I had to ask myself.. does it matter? I would rather get a quality product from china instead of a product made by some DA that thinks he deserves $35 a hour to make a $10 product..
I wish Toyota or Nissan would bring over a diesel in a 3/4 or 1 ton truck.. at least I know i'm getting quality..
Sorry to HJ ;-)
Old Feb 3, 2009 | 11:42 AM
  #32
vettdvr's Avatar
vettdvr
Sorry to HJ ;-)
I lived in China for a while complements of USAF and 99% of the locals worked exceptionally hard to do a good job. I would also buy China if it is a better product.
So I would buy DB if I thought it were a better product. This is what free enterprise is all about.
Old Feb 15, 2009 | 05:38 PM
  #33
whitesdford's Avatar
whitesdford
I just put in the DB high torque starter, it made a huge difference! Made in China or not, it appears to be a better starter than my old worn out one.
Old Feb 15, 2009 | 05:53 PM
  #34
F350-6's Avatar
F350-6
I had not heard of this, or even thought to ask. I was under the assumption they were a rebuild shop. I know they offer powerdercoating on their alternators since I ordered one for my wife's truck. The housing that showed up powdercoated pink (so I know they had to do it, no one stocks a pink alternator) was stamped Motorcraft.
If you're referring to them using chinese parts to rebuild the stuff, then I wonder if there is a US alternative for those parts. Any one else have any knowledge about this?
Old Feb 15, 2009 | 07:05 PM
  #35
Hiflyer746's Avatar
Hiflyer746
While at work a month ago or so. . . I heard the sound of an impact wrench. . . and then a semi running. It had an air starter on it and I thought that was the coolest thing. Anybody ever seen them?
Timmy
Old Feb 15, 2009 | 07:20 PM
  #36
Kwikkordead's Avatar
Kwikkordead
Timmy
I've only heard an air starter once in my life and that was 30 years ago now. I thought it was pretty cool at the time as well.
A google search revealed this.
Some of thier larger starters are rated for 40,000 cid engines!
Air Starter Components
Old Feb 15, 2009 | 07:44 PM
  #37
rbaker6336's Avatar
rbaker6336
where do you think the starter or alternater you would buy from ford is made
the original starter is made by Mitsubishi
Old Feb 15, 2009 | 07:59 PM
  #38
JockD's Avatar
JockD
I had a Caterpillar 545kw generator set with a 3412 engine (think of two 3406 truck engines set up in a V configuration) that had an Ingersoll Rand air starter. It sounded like a huge air impact wrench air motor - and LOUD!!! Believe it or not, it seemed to use very little air. I accidently forgot to open the valve to the storage tanks one time and started the engine from dead cold (sitting over a weekend at 40* F) on what was in the 1 1/2" air line that was 16 feet long. We stored the air at 175 psi, but regulated it down to 100 psi at the starter.
Old Feb 20, 2009 | 01:09 PM
  #39
bascars's Avatar
bascars
I was a little hesitant when ordering since the number of splines did not match up, but they convinced me that it was the right starter. For the price there was no debate. This starter was less than a rebuilt stock starter, and with the positive feedback from others on this site I decided to go with the DB. The only downside was that I was waiting for this starter during the big ice storm in Kentucky (and surrounding states) and I didn't have my truck. I was amazed at the size and overall robustness of this starter. I was able to get the starter in, but it was contacting the crossmember. So I ground that down a bit. Not really expecting the completely different tone to the starter, I thought that it was the wrong one. I have been using it now for a month and am impressed with ease of starting. I would definitely recommend this starter to others.
Old Feb 20, 2009 | 01:33 PM
  #40
spdmpo's Avatar
spdmpo
Well thanks for posting this up. It made my destacision and I ordered one up today. It's been pretty cold around here lately and I've had a couple hard starts lately. Not from not firing, but from not getting the engine spinning fast enough. The batteries would drain real quick if I had the key in the accessory position if I was doing something or even had the radio on for a more than 10 minutes. Basically I had one shot at getting it started, there was no reserve. I got two new Motorcraft batteries in there this morning when it died while cranking. Now it's great. Decided to just go ahead and go for the starter too...looking for overkill here.
Old Feb 20, 2009 | 02:30 PM
  #41
brian42's Avatar
brian42
Veteran: Navy
The military has been behind the cost of living ever since it's inception, so I like to save where I can. If Ford wants to sell it's OEM starter for $250+ and use that overhead margin to cover paying a factory forklift driver $85K/year or pay out MILLIONS in salary bonuses, that's their perogative. If I want to save $100 and get a more powerful starter (from China instead of Japan) then that's my perogative.
By the way, that forklift operator makes more money a year than I do operating nuclear reactors for the Navy...so I'm not putting any more money in his pocket than I have to.
Old Feb 20, 2009 | 03:30 PM
  #42
Ziggy.'s Avatar
Ziggy.
I put mine in this past tuesday, I did have to grind some off the crossmember, but all in all it took about 30 minutes. Trust me it should have no problem spinning fast enough for you. It was around 20* outside this morning and when I cranked it up, it took less time to fire than the stocker at 50*, I took a look at the spec sheet that came with my starter when they tested it, and noticed the rated load RPM was 1411 rpm, Like I said, you shouldnt have a problem with it spinning it over quicker, you'll love it
Old Feb 20, 2009 | 03:38 PM
  #43
brian42's Avatar
brian42
Veteran: Navy
I have the DB HT in my garage waiting for some project time (work, wife and kids take up almost all of my time). Did you have to grind much? I have an electric 4 1/2" angle grinder, would that do the job? Did you do anything to preserve and prevent the crossmember from rusting?
Old Feb 20, 2009 | 03:45 PM
  #44
vettdvr's Avatar
vettdvr
Was this a 4wd or 2wd the crossmember is an issue and how much grinding? Does this weaken the member?
Old Feb 20, 2009 | 03:50 PM
  #45
F250_'s Avatar
F250_
Originally Posted by vettdvr
Was this a 4wd or 2wd the crossmember is an issue and how much grinding? ......?
I have the same question, and can only assume that he has a 4WD truck. My install was on my 2WD truck and I had about 1/4" of clearance in getting the thing in placed adn bolted up. Tight... but not so tight as to require grinding.
In terms of faster spins... that's an absolute improvement without a doubt!
