trailer question...or two
Old Jan 29, 2009 | 10:40 AM
  #31
joe_13894's Avatar
joe_13894
Very quality work Ryan,
Don't you love that a guy fabricating his own gets it right, but all the "professionals" don't?
Old Jan 29, 2009 | 02:59 PM
  #32
Cuda_jim's Avatar
Cuda_jim
Originally Posted by Dave Sponaugle
Don't remember, last summer or two summers ago about 60 miles north of me a tree crew towing a chipper with less that desireable safety chains lost the chipper.
Crossed the road, slammed head on into a mini van and killed three people.
Now consider if your trailer breaks loose, something is wrong with your equipment.
So if it hits anything, you are at fault.
I personally want the trailer to stay with my truck if it breaks loose.
As long as it is attached, I do have a way to have input into where it winds up.
If I have to wreck my truck to save a family, they make new trucks every day.
If I die in the wreck, it was my own fault, I missed something when I inspected the hitch before I left.
If I kill the family with my trailer and I live, I am going to wish I was dead every day for the rest of my life and their lawyer is going to take everything I ever will have anyway.
I agree, but since we were talking safety chains and trailer brakes.....
When I pull things that don't have brakes I definitely check the chains.
Most chippers don't have them and can weigh way more than my truck is capable of stopping comfortably. I avoid trailers w/o brakes as much as possible.
Some of the scariest things I've seen towed are a little gas power cement mixer and the like bouncing down the road at 70MPH behind a 1/2 ton pickup with 2 tons equipment in the bed....dragging the bumper. Around here it's the 'wild west' on the hiway, almost anything goes. Heck the big guys are allowed to gross out at 160K pounds...Hence the Michigan Special.
BTW: My break away only energizes the right side brakes....almost guarantees it going in the ditch.
Old Jan 29, 2009 | 08:39 PM
  #33
MissIndependent's Avatar
MissIndependent
Originally Posted by nelstone74
The whole rated or actual weight deal has more to do with the highway patrol handing out tickets. Best advice I can give is to know what things weigh and keep your equipment in good repair and have a routine for hooking up so you never have use the saftey chains
routine for hitching up = triple-check everything and then make someone else go behind me just in case. should probably think about doing that for unhitching...have the bad habit of setting cotter pins, etc on my bumper and then forgettin about them
oh so let's get even more detailed with safety chains: what kind of snap/hook do you use and why? and which way do you attach them? (facing out or towards truck bumper)
Old Jan 29, 2009 | 10:38 PM
  #34
c00nhunterjoe's Avatar
c00nhunterjoe
idelay you should have the weight of the chain pulling on the loop, not the hook, it all depends how you hitch is designed as to which way the hook faces.
cuda, you'd love to see some of the stuff we have on trailers at work.....next time we get outside the gates i'll try to get a picture. how about a tri-axle tractor with 700 horses pulling a 14 axle trailer with an 85 ton tank on it??? take a wild guess what the total weight is on that puppy
Old Jan 30, 2009 | 05:20 AM
  #35
884x4broncoII's Avatar
884x4broncoII
i have had my boat come un hitched one time, i did not put an pin in the hitch latch. i was going pretty slow went over an set of train tracks trailer came unhitched. i was damn glad i had the safety chains on, with the chain criss crossed it kept the tongue from hitting the ground. and the tounge of the trailer was long enough that when i stoped the safty chains kept the bow from slamming into the tailgate. i would say that the each chain should be strong enough that the trailer should be able to be hung compleeetly in the air by it. i strap down things to my trailer with the same thinking, i immagin haning the trailer upside down and think to myself would this stuff still be on the trailer.
Old Jan 30, 2009 | 06:48 AM
  #36
Neal 97 250's Avatar
Neal 97 250
I have seen that setup. Actually we used that tractor and trailer, possibly the same one. Funny thing is that we used it to move a 20' intermodal container (kinda like a roll off container or dumpster). It only weighed 40K. Looked alot like a fly humping an elephant. Waaaayyyy to much truck/trailer. And talk about tires they go from one side to the other, I think 8 tires on each axle. Well not an axle but where it would be. 8 tires wide.
That was a good catch. Bet you were glad you crossed them.
Good thinking on the hang upside down idea. Wonder if 2 stroke man could have done that with his 10.5 wide by 13 foot tall load of hay he took over hwy 80 4 times. LOL
Now that is a load and talk about illegal !!!!
dchamberlain
All Things Towing
60
Dec 23, 2008 06:45 AM
Greywolf
All Things Towing
Oct 6, 2006 09:30 PM
chadsalt
All Things Towing
61
Jun 6, 2006 08:42 PM
fordcountry
Mar 26, 2005 08:41 PM
samahi72
All Things Towing
22
Mar 17, 2005 05:19 AM
