C6 with overdrive unit
Old Jan 29, 2009 | 08:23 AM
  #31
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by don77
benshere just shut off overdrive when taking off then i no many that do that
That doesn't have anything to do with the torque converter locking. It will still lock the same, but with the overdrive off it won't shift to fourth gear.
The E4OD will lock in first and second gear if the go pedal is on the floor. It does it by RPM, but as was mentioned above you need some load on the truck or it will upshift the trans before the lockup happens.
parsons913bp
Dec 14, 2009 09:34 AM
Shade
Aug 24, 2008 03:13 AM
jav409
Jun 12, 2008 06:38 PM
rob8210
22
Feb 25, 2008 10:59 AM
booman
17
Jun 7, 2007 07:08 PM
