Iv almost finnished installing a ( Doug Nash ) US Gears overdrive into my 66 F100. It is a .8 overdrive. the engine is a
352 4bl C6 3.07 Gears and 29 in tires. going to pickup the one piece Drive shaft tomorrow. All the rest is installed. Soooooooooo
A question about Tq converters and stall speed. The Tq converter I have is a stock one and I figure with the overdrive my highway RPM at 65mph to be around 1850 -1890 some where in there. Is the stock Tq converter going to
be ok or should I be looking a lower stall converter. The C6 Does have a shift kit in it. and will stay in whatever gear I select or shift thru the gears in Drive.
Anybody that could shed some light on this stall speed thingy ?
