EBPV Plug??
Old Jan 24, 2009 | 04:25 PM
PsD007.3's Avatar
PsD007.3
EBPV Plug??
where is it located?? i wanted to unplug it..In doing this will it throw a check engine light?? I think mine be sticking shut sometimes....eventually i wanna get a high flow outlet and non ebpv pedestal with garretgpr38
Old Jan 24, 2009 | 04:34 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
its on the very bottom of the pedestal, behind intake "Y" you cant miss it...and no it wont throw SES light, i didnt have mine for years and only had soft code no SES ...
Old Jan 24, 2009 | 04:36 PM
PsD007.3's Avatar
PsD007.3
ok monday i'm going to take a look, soo if i stand on the passenger fron tire i can miss it by looking down there? i'm guessing its ikn front and not behind the pedestal?
Old Jan 24, 2009 | 04:38 PM
PETE'S_6.0PSD
yes its in the front IIRC and has a clip , just unplug it, flashlight would be good too...
Old Jan 24, 2009 | 04:42 PM
PsD007.3's Avatar
PsD007.3
IIRC?? i'm farely new to this bud lol
Old Jan 24, 2009 | 04:43 PM
PETE'S_6.0PSD
If I Recall Correctly
Old Jan 24, 2009 | 06:10 PM
Steve_250's Avatar
Steve_250
What is the benefit of unplugging it?
Will it disable the automatic high idle on a cold day (turbine noise at exhaust)?
Old Jan 24, 2009 | 06:38 PM
PETE'S_6.0PSD
well no innoying noises, and no affect on hi idle..., maybe better flow if you remove it. Vans dont have EBPV valves, theu used for faster worming of the engine. EPA bullsit
Old Jan 24, 2009 | 06:48 PM
swaybar's Avatar
swaybar
what is the differance if i just unplug my ebp-sensor, "in front of my hpop", is it connected to that. or is this something completely differant?
Old Jan 24, 2009 | 07:11 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
they are different. the plug on the pedestal is actually the switch for activating the valve. the one on the hpop is for sensing temps to activate the above said switch.....
Old Jan 24, 2009 | 07:16 PM
swaybar's Avatar
swaybar
so would unhooking just the SENSOR de-activate the valve?
Old Jan 24, 2009 | 09:21 PM
southpaw37's Avatar
southpaw37
Just unplug it on the pedestal.
cork13
Apr 2, 2014 05:03 PM
jleal_21
Jun 20, 2008 11:40 AM
BLACK F 350
Jul 22, 2006 12:39 AM
vpofscc
16
Apr 14, 2006 01:22 PM
jadel
Feb 9, 2005 11:14 PM
