EBPV noise
Old Mar 29, 2014 | 10:03 PM
cork13's Avatar
cork13
Question EBPV noise
Will it give me trouble if I unplug the EBPV sensor. Trying to cut down on the noise at warm up.
Old Mar 29, 2014 | 11:30 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Nope. Go ahead.
Old Mar 29, 2014 | 11:39 PM
clem1226's Avatar
clem1226
You talking about unplugging the exhaust back
Pressure valve or the exhaust back pressure sensor?
Old Mar 30, 2014 | 09:05 AM
cork13's Avatar
cork13
Its the plug on the pedestal, it seems to keep the valve open with the plug out with less warm up noise.
cork13's Avatar
cork13
Sorry I mean valve open.
Old Mar 30, 2014 | 09:43 AM
cork13's Avatar
cork13
Reading other forums they say to clean the BPEV tube and keep it hooked up, it effects cold start ( with it disconnected it did seem to start harder) and fuel mi. Next I think I'll try cleaning out the tube and sensor. Any info on this?
Old Mar 30, 2014 | 01:22 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Make sure you understand the difference between the website and the valve. They are not related. The valve is for cold starts and the sensor is for PCM calculations.
Don't disconnect the sensor, but the valve is fine. It won't effect starting. All it does is increase load on the engine to warm up faster.
Old Apr 2, 2014 | 05:03 PM
Eskipper20's Avatar
Eskipper20
Will cleaning this help prevent the valve from sticking open? When I start my 1997 7.3 and its below 40 degrees sometimes and let it run anywhere between 3-5 minutes I will drive off and the truck sounds like I have an exhaust brake on that doesn't work. Whenever I try to cruise down the road or accelerate(sometimes) It feels and sounds like I have an exhaust brake going.
shanett306
Jan 6, 2007 02:34 AM
daleper
Nov 11, 2006 05:40 PM
javi2001
Dec 11, 2004 08:55 PM
trakker
Aerostar
Oct 20, 2002 01:16 PM
